Until we get rid of the "ears in the rear" (stupid ass bumper steps) nobody's going to win any shows lol
I'm going to have to address this sooner then later :)
I've got a first in class & a third overall trucks.
:P
SweetSilverado, I didn't actually use a kit, I used McGaughy's 2" shackles in the rear and removed the factory 1-1/4" block. On the front I used Rough Country's lower strut mount for a 2" drop. Cost $88 total + alignment. I've used spindles, springs, struts and flip kits in the past but wanted to give the Rough Country lower strut mount a try this time, and so far, I'm happy. No bumpsteer, no driveline vibrations and it drives/rides as it did stock. I would like to bring the rear down another 1/2" but its going to require some nifty fabrication... I'll tackle that another day.
Is you're alignment within factory specs? I have spring relocators in the front They couldn't get mine perfect till I get offset bushings. I might have to order a camber kit from belltech.
Sorry guys I'd normally quote your reply but I can't figure out how to do from the Android App...
Mine did align to within specs, but there isn't anymore adjustment left. I will also note, just because mine aligned within spec doesn't necessarily mean yours will. I read just about every forum on the world wide web before I lowered my 2013 crew cab 4"/5" and the general consensus was if I lowered it using the BellTech 647SP kit it should align with the cam bushings that come in the BellTech kit. That was not the case with my truck. It was WAY out and couldn't get it within spec without adding a cam kit. Apparently, the tolerance on the frames and mounting hardware was fairly broad.
Hey guys I've been lurking around here trying to get as much info as I can, I should be ordering a RCSB 4WD (it snows here) this week and I plan on doing a 2/4 drop on it.
Anyway I thought this might be helpful for those of you with vibration issues
http://www.hurst-drivelines.com/files/Universal_Joint_Alignment_Proc_111606.pdf
Also does anyone know why you can't buy a flip kit for a 4WD? Is the rear axle different in some way?
Excellent info for everyone in this thread
TJay.... Can you verify something for me because I am the only one that seemed to have this problem because nobody else is reporting it. Now I fixed mine before driving but it could be the noise you are hearing.
You won't be able to see it without a small mirror or you will have to take a picture which is what I did using my phone. Crawl underneath your truck and just above your spring where it bolts to the drop shackle, see how close that bed seam comes to the spring. I was touching on one side and only had 1/16" on the other... Yours is a 4x4 and mine is 2wd so it may be different but if you are hitting the bed seam it would certainly be your issue.
This is crap... Now it's all jumbled up and hard to follow.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
