Put the belltech 2-3" shackle in the back a couple days ago and left the block in. Truck sits with a 1/2" squat with it installed at the 3" hole. The front probably pivitided upward slightly to make it lower in the back now. Thinking of going to the 2" hole and hope it'll make it a 1/2" rake cause I'd much rather that. this thread has been super helpful just reading it. Here is what she looks like with a slight squat Wanted to call it darth vador but someone beat me to it on here lolpost-160818-0-04873000-1469651933_thumb.jpeg
Put the belltech 2-3" shackle in the back a couple days ago and left the block in. Truck sits with a 1/2" squat with it installed at the 3" hole. The front probably pivitided upward slightly to make it lower in the back now. Thinking of going to the 2" hole and hope it'll make it a 1/2" rake cause I'd much rather that. this thread has been super helpful just reading it. Here is what she looks like with a slight squat Wanted to call it darth vador but someone beat me to it on here lolattachicon.gifimage.jpeg
You could always change the chrome that's left to red and call it Darth Maul.
Sent from my SM-G935V using Tapatalk
That's true haha. I've got a few different colours of vehicle wrap so I can change my emblem any time, red being one of them lol
Looks great!
Looking good,you happy with the drop is that like a 2/3 drop?
I like it. I really wanna somehow drop the rear 1 more inch though. Not sure about a 3" drop shackle as it doesn't look like it will fit.
Did you need alignment how's the ride?
I have the 3" shackle in my truck with the block still in and there isn't much clearance between the bump stop. With the block out i would have to cut the bump stop or get aftermarket one.
Edited by Cdoan3
I didn't know there was a 3" drop shackle. I thought there was only a 2" and to get 3" you remove the block. Most have to flatten the bed seam to fit the 2", so how tight is the 3"?
Belltech has a 2-3" adjustable shackle available. My dealership orders the shackles in and when I got it back that's what was in there. When I looked underneath it looks like the guy that installed it lifted the box cause the seam isn't folded. I looked up the part number to find this out it was the 2-3" adjustable shackle. I'm thinking of putting the adjustable strut belltech has so I can get a 2-4 drop without flipping the axel. Oh and I have no vibration or anything with it at the 3" hole. Edited by Cdoan3
I thought it was a 2" shackle and removing the block for 3" on 07 and up. Then they have another shackle for 3" drop but that is for the HD models
What are the rear ground to fender measurements? Wonder what they did? A 3" shackle on these truck would in the bed, what was the part number on your shackle?
Edited by wuznme
That's what I understood too. The shackle in Belltech 6400 and 6401 were both a 2" drop, but the 6401 kit came with spacers to put between the nuts and plate on the axle because the threads weren't long enough when you removed the lift block. I just bought the 6400 and 2WD u-bolts so I didn't have to use spacers.
Sent from my iPhone using TapatalkI
I did require an alignment. The front rides great. The rear is a little stiff but that should change after I get the new belltech shocks on.
Also with the 2" shackle I did have to fold the bed seam.
just got a 2016 CCSB sierra slt 2wd. first mod i did was replace the factory 20's with some black OE replica 24" rims on 305/35/24. thinking about just lowering the rear to level the truck out with the front. a little apprehensive though after reading about the issues with driveline vibration. need some advice. would the dealer do the installation? how much does the rear have to come down to level it out?
Edited by ozone
    goetzmann
    goetzmann
  • Who's Online   5 Members, 1 Anonymous, 561 Guests (See full list)
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
