11 hours ago, Daly said:
Those with Drop strut's or drop spacers for the strut's have any issues with alignment after? I'm still up in the air about levelling or lowering my truck and I've thought about getting Bilstein 5100's and installing McGaughy's 2" drop spacers on the 5100's set at stock. That way if I don't like it I can just switch to levelled, with out having to order more parts, may even just use the stock struts first. In the back I'll remove the block and install a 2" drop shackle. That way if I want to go back up it's an easy reversal...
I have 2'' drop shocks in the front and my alignment is in spec. I think I'm right on the max adjustment for camber though, if I remember correctly.
Down 4.5 in front with spindles, struts, and springs...still aligns within spec.
I figure with Spindles the alignment will be fine, I just wanted to make sure a 2" drop from a strut will be fine. I had my feelings it would be, as it's really no different than going up, there must still be some adjustment. Just wanted to make sure I wasn't going to be getting into UCA's or anything. Thanks guys...
Finally installed my shackles this weekend. Not completely level... I'm debating on dropping it more. 5b72223bd1397abcee0f0486d1d82ef0.jpg
Also trying to get mounting hardware for my rear fender liners. No way I'm giving GM they much money for that stuff [emoji23]
Also what's your driveline angles looking like when you pull the blocks on the axle? Any degree wedges needed?
Just pulling the blocks wouldn't change enough to insert shims, but blocks in combination with shackles might.
On 3/23/2018 at 9:48 PM, Stressin said:
The slight change in angle of the leaf places the axle slightly further forward when the suspension is under load, and it no longer lines up with the notch. Axle is hitting the frame right where the notch begins.
The notch also may not have been perfectly centered to begin with.
Just to follow up on this:
The notch was definitely not centered to begin with. I put the 1/2" lift shackles back in and jacked up the differential to get a better idea of what everything looked like before I switched to the 1" lowering shackle, and it's the same. Working with the installer on a solution.
Blocks/shackles is 3", you lower it that much under load or when towing. If that causes a pinion angle problem there is an issue. No problem with mine...
Sent from my Pixel using Tapatalk
Yeah I just got the shackles in this weekend. Wanted to make sure I didn't need any degree wedges before yanking those blocks
I'm down to 2/5 now.  the front is 1/2" higher than the rear.  My drop spindles will be in next week.
Nice!
Any chance yall recall the socket size on those ubolts? About to pack tools up from work to carry home
21mm
21mm
Sweet thanks. Looked up the specs looks like they're torque to yield. Gotta get new ones?
everyone reuses them
I reused mine. Probably gonna get new ones when I install the caltracs though... Torque to yield 3 times is a bit much lol.
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,586 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
