How i would do it is put 2 rings in front bringing it up to 3" drop.  And then drop the ass end 1 more inch making it a 3/5 drop but thats just me
Copy that! Man I really appreciate the help and quick replies! You don’t see that much these days. Thank you!
Ive messed with my suspension so many times i can do it in my sleep.  Im currently at a 4.5/7   soon to be 5/8.
I went from 3/6 to what i am now. You wont like 2/4.  Just go straight to a 3/5. And your stock tires willstill be fine
I have the same truck and color!
Nasty, what is not good about the 2/4?
Not that I was thinking of that combo...I wanted to go as you mentioned 3/5, but didn't want to flip the axle and make cuts.
So, I'm on the fence and thinking of just removing the rear blocks and 2" shackle, but I would think my ass would be too low and front at stock height?
Also, does lowering the truck help diminish roll during turns or is there a stiffer sway bar and springs that need to be changed out?
I don't mind a stiff suspension as long as it does what it's supposed to do and there's no hacking/welding on the frame.
2/4 on these trucks doesnt even look like its been lowered.  The only cut you make is the bump stop mounts.  Which is nothing
My truck actually rides better then it did stock
If I cut the bump stops, will that mean I can't go back to stock later?
Cut them off straight like i did. So they can be welded back on   i qont have to worry aboyt that because im getting a notch
3 hours ago, Nasty said:
4 hours ago, Breedsrt said:
That looks great!!!
Yeah, you dropped it 4'' in the front with the springs and shocks.   I wish mine looked that low in the front with my 4'' drop.
Edited by qwank
Looking at 2 different kits...2/4 & 3/5 from 2 different manufacturers.
I know there's a lot of people using the BellTech 2/4, but does anyone have experience with MaxTrac 3/5.
Belltech lowers the front with struts, where MaxTrac lowers the front with spindles and springs.
My thought is with Belltech the use of struts only and keeping the OEM spindles may have less chances of bad handling characteristics/fit issues, should the spindles be slightly off one way or another.
However, I'm not sure if this has happened or how good their kits are quality wise..hence any experience with MaxTrac spindles and springs?
Another question, how much carrying capacity is lost when the rear is lowered without using bags?
Always use spindles if you can
Can you elaborate on why you feel this way, and have you used MaxTrac before or know of anyone that has?
1 minute ago, qwank said:
Belltech has spindles also
Are you using these on your truck?
If so, do you know the kit number?
Yes, I am using these on my truck. You have a 2016 so the part numbers are different depending on which control arm style you have. I used part number 2514 which fits stamped steel and aluminum control arms.
When you lower 07-18 silverados with struts pr spring. The lower you go, the farther back the front wheel goes back into the wheel well. Which causes mkre rubbing and looks horrible.   Spindles wont affect that
Yes, I just checked the sight, and I have cast control arms. My truck is an early 2016, and the kits say aluminum.
I'll reach out the to sales person I talked to earlier to see if they have spindles for cast CA...Thanks!
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
