21 minutes ago, DESERT DOG said:
Are you going to 20's then? I think the 22's fill the wheel housing a little better, but don't want 24's because of the ride issues.
I had 20s. Went to 22s, back to 20s, im on stock 17s now.  And now ifound mynew wheels so going back to 20s now
What are the new wheels?
American racing ar926 on a 265 50 20
Edited by Nasty
Cool.  What color you going with? (assuming they have multiple options)
Chrome   theu come in chrome or black woth machined accents.  (I hate black wheels and nothing on my truck is black so chrome was an easy choice)
3 minutes ago, DESERT DOG said:
Nice wheel.
They fit the look i want and they have a nice little lip on them
Is the hub size matters? I know AR926 has a bigger diameter than the OEM (78.1mm). If that so, do we need to  install some sort of an adaptor to make it fit?
Yes they have 106mm hib bore for toyota but toyota has same lug pattern. They come with hub rings. Same thing when i have my american racing supetnova 6 wheels a few months ago. You just use the supplied hub rings
On 07/12/2018 at 4:12 PM, DESERT DOG said:
Finally got around to taking pics after it was lowered. Now to figure out what wheels to go with.5c0af031ed8f2_bFrWzZO-Imgur.thumb.jpg.2f9472cb4c1f39f59fa3a1557415521f.jpg
What setup is this from stock... 3/5?
Thanx,
Krunch
It is the 3-4 5-6 adjustable Belltech kit. I am at about 3.5 front and 6 on the rear
Thanx,
Krunch
On 11/9/2018 at 7:12 PM, SirenRed16 said:
So I did a quick measure and I'm at 17.5 driver and 18 passenger
Did you go to ground control to fix the drop?
2 minutes ago, SirenRed16 said:
Ground control a shop?
Yes
That's kit is not adjustable to a 1/2" is it? Or based on before and after measurements this is where you landed?
Thanx,
Krunch
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
