I will take pictures of my location and try to take some measurements even though tire size is a factor on where my wheel will sit after it's dropped with a 2" spindle and 1" strut.
Finally got around to dropping the truck. 2" belltech spindles and belltech flip kit at 5". May go another 1-2" up front and 1" in the back next year.
On the look out for street tires, but until then. I'm happy with it.
  • Like 5
Truck looks great. I would drop rear another inch but other than that it looks good. I like that color.
Had it at 6" originally, looked like it was squatting, so put it back up. Plus I do still tow and use the truck so I wanted some rake.
Edited by Daly
finished up the drop. can’t drive it. too much negative camber if that’s the right term. top of wheel is toed in hard and any speed causes tires to scream. install wasn’t bad at all
If you drop the truck yourself, the first thing you gotta do is get an alignment. If you know how to manipulate stuff, you can eyeball it to get close enough for a short drive to the alignment shop. Truck looks good though!
Looks good.  Great color and the drop looks right on for the truck.
Got the Twisted Metal Workz upper control arms installed on my truck today.  It was late and I didn't have time to snap any photographs but will try to do so in the next couple of days.  The wheels moved forward as advertised.  They only rub right before full lock now.  Lot of money/time to move the wheel forward about a half inch but I am happy with it.  Looking to get rid of the last bit of rubbing I can either go down a tire size or potentially step down from my 1.5" wheel spacers to a 1" spacer.  I don't want smaller wheels as I like the look filling up the wheel well like they currently do.  The spacer change I might do.  I went with the 1.5" spacer as I understood that smaller spacers would require trimming the bolts and I wasn't sure I wanted to take that step.  Now after talking with my installer he said it was no big deal, and that basically it is something they do regularly (my paraphrase).  Any one here had that done?  I do like the wheels sticking out but I have thought since ti first got done that I really would like them to come in that 1/2".
Looks great!
Here are pictures of my front wheels.  Damn near centered.  Very happy with the new arms.
Has anybody had luck or experience with the max trac 1 inch lower springs for the front? Looking to drop the front of the truck an inch and 2 inches in the rear. It’s a 4x4 2018 Sierra CCSB
Went ahead and ordered them. Also ordered 1.5 inch drop shackles for the rear leafs, since I’ve already pulled the 1.25 inch blocks out of the rear, that’ll give me 2.75 drop in the rear and 1 inch drop up front. Should maintain just enough rake to make me happy, and the ride shouldn’t be too affected.
Hi all,
I read a ton of this forum as well as on , lifts, lowering forums, trying to determine what would be needed to run bigger tires. I like the look of the level kits but I also love the way the stock truck handles and I don't want to risk changing that or wearing out front end parts. I do however like a bigger tire. I have a tire machine in my shop so I decided to get some different used tire sizes from the recycle drop off and try them. I found 275/60 R20 fit well with no rubbing on a stock suspension. Subsequently, I put on Hankook I-Pike Ice radials on the original snowflake rims to use for the winter and try them out. The rims were a special order on a previous truck, 2014, and I kept them for the 2016. They didn't last very well with lots of chrome peeling so they will be my winter wheels now.
I just wanted to share 2 things.
If you don't want to change your suspension, 275/60 R20 work fine
If you do go to a taller tire, it definitely effects the driveability. At least in my truck with the 8 speed. Although the tires are only 3% bigger in circumference I definitely notice it when starting out and on the highway it tends to lug a little.
I still like the larger tires though, it seems to ride smother and I like the look. I may drop the rear a little in the spring with shackles to lower the back when I put on some all seasons with new wheels.
2016 Sierra SLT Crew 4x4 6.2ltre
Hankook I-Pike 275/60 R20
Stock rims
    TopBo
    TopBo
  • Who's Online   3 Members, 0 Anonymous, 1,537 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
