I apologize if this have been covered, but after reading so many posts on the topic, I want to make sure I fully understand what is and is not functioning after the swap.
If I understand correctly:
  1. Everything inside the console fully functions with the connectors/harness that is used for the old jump seat console.
  2. Do the connectors/outlets on the back of the console function? If not, can they become operational with a modification?
  3. The front usb ports can be used for charging with a modification
  4. The front 12V outlets can be used, but require you to tap into a 12V source.
  5. Has anyone gotten the 110V outlet to function?
Thanks in advance for the help. I just purchased a 2014 Silverado 2LT 4x4 Friday, and this is one of few missing items I wish it had (but the price was too good to pass up).
Nick
I'm going to guess this all depends on what you start with. My truck (LT) came with the 110V plug in the dash down low next to the ash tray. I also had a cigarette plug there as well. Mine was as easy as just transferring these over to the new console. I doubled up the lighter plug by soldering another set from the left over harness. The other stuff in the jump seat convert over to the new console. You will also have to run power to the console light in the box. When all is said and done, the only thing not functional is the front 3 USB ports in the front of the console. You can run a couple cables and get power only for charging, but they do not seem to work for integration into the stereo. Hope this helps, good luck.
Edited by krdeal
Got mine done this weekend. Came out great. Thanks for all the contributors on this forum. I don't have USB functionality on the front 3. I did Bilsteins, Console swap, and Katzkins. It was a lot to take on in one sitting. I thought it would be easier to knock out the Katzkins and center console together. Looking back, it was enough work that I probably should have done the jobs separately. The console swap isn't bad, but combined with Bilsteins (3 hours) and Katzkins (12 hours), it was overwhelming.
As far as the console swap by itself, I followed the directions in this thread and had very little trouble. The wiring is easy, but you have to think, plan, make sure everything will fit, etc....Make sure you have a good soldering iron, shrink wrap, and wire strippers for 20 Gauge wire. Someone could write down a super detailed description about wire colors and exactly what to do, but it's mostly intuitive.
Basically completely remove all the tape and salvage the USB cable from the jump seat. Unplug the console USB and let in hang in place. Plug in jump seat USB in its place. This will plug in to the harness under the seat as it did before.
Cut 12-14 inches off the jump seat harness. Solder all similar colors. There will be two extra (purple and yellow 14 gauge I think) on the jump seat harness side and one on the console side for the light (20 gauge blue and red). Tape up the purple and yellow. They will not be used.
Salvage one cigarette lighter harness from the jump seat and cut with 8 inches of wire. Cut the ashtray cig plug where you have enough room to solder/splice it. Solder the additional cig lighter harness to the existing one along with the 20 gauge light wire. I think I had to extend the light wire with some salvage wire as well. Now, where there was originally one cig plug with full time power, you will now have 2 cig plugs and the console light in a three way splice.
This gets everything but the front USB's working. I ran out of parts, brain power, and patience to attempt this.
So inverter is plug and play. USB under lid is plug and play. Rear cig, under lid cig, audio are fixed with the soldering of the harness. Additional front cig and light are spliced into existing cig.
Does the center console have any room to run a duct to the rear?
Yes, except the light. And you have to completely swap the USB cable over (plug and play).
Swapping out (cutting the jump seat harness and replacing the console harness) the harness gets the back cig plug working just like the jump seat.
Yes, I didn't do this though. Mine are dead.
One of them will plug right in. But the console has 2 where the current ashtray has 1. You have to splice power from the other one and steal the connector with 6-8 inches of wire off the jump seat one. Also, splice the console light in here as well.
It is plug and play if you have the inverter currently. There are two tiny harness clips.
Nick
For the number 4 y can run a wire with the correct terminal from left block fuse. (it have a fuse already installed and nothing connect to it) then this way you have 2 x 12v with 15 amp on each. You can also do the same with the rear socket in console (the one for rear seat) but need to run a wire from right block fuse. There is also a fuse with nothing connect to it
Left block fuse is always powered and right block fuse is R.A.P. (powered 10 min after key is removed or until driver door is open.
Light and usb for charging can be tap on the front 12v socket
Anyone do this without the bracket to the dashboard? Any issues?
The bracket is not available anywhere at this time with no availability date.
Hopefully, I will tackle this tonight, I finally got all the pieces in that I needed. Wish me luck!!
I always wanted a RCSB with buckets and a center console...
Received and installed mine yesterday. Very straight forward, thanks for all who posted instructions and part numbers.
Possibly to help others, here are the part numbers I used...
22995066 Console - Jet Black w/chrome handle (inside 2 USB, 1 SD card slot, aux jack, 1 12V outlet) (rear 1 12V outlet)
22995093 Plate - Synthesis (front 2 12V outlets, 3 USB) with cup holder
22817347 Panel - Black (right)
22817349 Panel - Black (left)
22776807 Bracket (was told by two suppliers this is no longer available from GM)
Installed without bracket to dash for now. Console is very solid with no movement or vibration at all.
I did not need to remove either of the seats.
Used the harness from my jump seat and spliced in console lead to rear 12V outlet.
Existing 12V in dash split for two front outlets with console light powered from these outlets as well.
Everything works except the front USB's.
Photos...
Edited by dla
  • Like 7
Help please, I did my install last night, everything went very good, and everything is working except my front usb, I did use the #4 and #6 wires to the front usb, by jumping power from the cig lighter, but it isn't charging, do I need another wire in this, or what am I missing?
For usb charging you need to have radio option io4,io5 or io6 (because they are the only option that have a HMI behind the lower glove box) then you need to plug a mini usb male inside the usb socket until the HMI with the other side of cable that it is also a mini usb male
This cable can be done with 2 cable (cut and sold them togheter)
Or be bought but the only place I found some was on ebay and hard to find
Hope this will help for usb charging. And don't forget you need a usb cable AND connecting also pin 4 and 6 to ground and Positif voltage
I completed the console swap today. Thanks to everyone who has posted in this thread for helping out. Everything is wired and functioning with the exception of the front USB ports. I will work on that soon.
I ended up using parts of the harness that came with the console to make it a cleaner install. That worked out perfectly.
The only issue that I ran into is that my console plate did not include the cupholder :nonod:. I bought most parts from GM Parts Direct, but bought the plate from eBay because a seller had a brand new one with the ports for $85 an it was the right color. I didn't realize it was supposed to include the cupholder. If I order one separately, it looks like they are $120. I'm not too happy about that.
Putting that aside, I really like it. It fits perfectly and looks fantastic.
Awesome guys how much does it cost ya'll to do the swap?
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
