Added matte black vinyl for more of a solid look. For the white trucks I think It looks good. 10 bucks for both sides i installed then i mean it's only a sticker
2014 Silverado 1500 V8 4x4 All-Star Edition
Where do you get the vinyl?
You beat me to it! Looks Great!
I bought those same led's back in August and my first attempt failed. Put them in my toolbox and never got back around to it.
Do you have any detailed pictures of the mounting you did?
I Never took photos of the fabrication or installation process but I did take close up shots of the LEDs once everything was done.
Ok so I didn't like the stock huge z71 sticker on my truck but I did want my truck to say z71 somewhere. Here's what I came up with. ...
What do y'all think? Personally I like it.
  • Like 7
I just installed the 14-15 Chevy Silverado 1500 Regular+Extended+Crew Cab Triple Chrome Taillight Trim Cover. I feel it looks good with the other chrome I installed on my truck.
http://www.ebay.com/itm/141256271383?item=141256271383&viewitem=&sspagename=ADME:L:OC:US:3160&vxp=mtr
The other option I saw was the following:
http://www.ebay.com/itm/V-Tech-2014-Chevy-Silverado-1500-Bowtie-Paintable-Tail-Light-Covers-ABS-Black-/331194802449?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ASilverado+1500&hash=item4d1cbfa111&vxp=mtr
Very slick! They run as daytime running lights or toggle switch?
Sent from my DROID RAZR HD
is that the GMC Z71 emblem?
can you post a pic of them on your truck?
I tapped into the low beam headlights, so they turn on whenever the low beam/DRL turn on. Which is pretty cool because they act like DRLs and are bright enough to tell. Thought about tapping into the amber city lights, but then decided I wanted them to turn on with the DRLs, plus pulling the wires to the city was a tad bit tougher.
Yes it is.
I know most everyone's truck came with this, but mine didn't. So I ordered the GMPP chrome exhaust tip with the Chevy bowtie logo. Put it on this morning and it looks much better than the raw piping.
Also installed my driver assist handle today.
Added two more OEM LED bed lights
Sent from my iPad using Tapatalk HD
That's handy. OEM? They only come with the two - left and right, so you got more of the same and just tapped them in - one on each side? Were the mounts already there?
BTW It looks like you got a boat hook similar t the one I just got to help grab those things that slide far away up front. ;-)
Edited by Mad Max
Yes, i bought another OEM set off of eBay and just spliced them in. Yes, one more on each side. No, there were no mount holes for the new set, so I just drilled 4 holes and used short metal screws.
The hook is called the EZ Retreiver by Access. I bought it from eTrailer.com. It telescopes to retreive stuff. I velcroed it to the Bedrog.
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
