Just realized my old truck made by Honda. :rollin:
Finally finish installed the heating pads for the rear seat. Can't wait to install it tomorrow. :driving:
  • Like 6
That looks like a nice tonneau. I just went with a tonnopro lo roll and I do love it, but yours looks a little cleaner at the tailgate. I have to pop my tonnopro and roll it back one roll then close the tailgate to get the seal to sit properly with mine. Not a big deal, but I would have preferred a system that allowed me to just open and close my tailgate without having to pop the cover every time. I don't open it all that often so not a huge deal, but convenience is key.
How do you like it? Does it seem like it will seal out water well?
The fit is really nice and it looks like it should be pretty much water tight.
I would just like a few pics if possible. I already have some LEDs just need to make sure i understand where to connect them.
In the drivers side footwell there are these connectors. For tying in your footwell lighting I tapped into the grey connector (far left) pin 1 (which is a grey wire).
Sent from my SM-G900W8 using Tapatalk
Whose kit is this?
^Rostra universal kits
All done. No more cold butt for the kids. :D
  • Like 7
Finally received the wiring harness I've been waiting for and so I finished the install of a JL XD700/5v2 amplifier to feed the Infinity speakers I installed in the doors a few weeks ago. Dropped in the subwoofer and box from my previous vehicle until I can buy a new JL TW3 to fit under the seat.
Been playing with the idea of tow mirrors, seeing as how the truck has some real offset now I think they'll look good but I haven't decided. What do you guys think?
  • Like 8
Looks good! I'd go for it
I would, I'd also put chrome caps on mirrors. To accent
Sent from my SG Note 4 on Tapatalk
Agreed. Offset the white and bit and help the chrome headlights stand out
Dipped my bow ties.
Looks good. remove the dealers name to start . more photo's
Dipped my bow ties.
They'll be chrome when I buy them but I may colormatch them just because I eventually want to get the chrome outta the headlights too. Almost all of it's gone off the truck.
    d.lowrey
    d.lowrey
  • Who's Online   1 Member, 0 Anonymous, 5,058 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
