I need to access to a module that is apparently behind the back seat as well. Haven't looked into it yet though...
It's just like on the older NBS trucks. You remove the seat and cut a little bit off the tabs that hold the seat back to the cab. When you fold the seat bottom up, the top half raises slightly and lifts out of the hook on the cab so it can be folded down for access.
Cool idea, just not for me. I have my kids in the backseat, so I won't jeopardize any safety from the seat.
Catch can installed and led lights
Sent from my LG-H810 using Tapatalk
Sooo not trying to be a dick but you do know your tailgate handle doesn't come close to matching the rest of your truck right? And for the vinyl Avery gloss white matches best...
Edited by Abearclaw
I know. I have the original handle that I will be sanding down and repainting to match. This one was shot with too much pearl.
I'll have more time when I go on my PCS leave to work on the truck more. Like doing my undercarriage before I move to the Midwest.
Edited by pamaguin
Got my Borla split rear "Touring" exhaust on......had the bro hook the truck up to HP Tuners and adjust for tire size and turn AFM off. Man what a difference now ....feels like a brand new truck!
Took the Sierra out for a warm up run then did a fluid check, oil good, transmission fluid good. After that I disconnected the battery for about 15 minutes for relearn. Found it odd that I had to cycle the drivers side window upon turning on the key. Took it out for a spirited run, and only hope it gets better with time/miles.
fold down? More info please.
So what I did was to remove the backseat entirely I did this so that I could install some be quiet brown bread against the rear wall and the floor in the process of doing so however I also cut the metal tabs that hold the back seat to the rear wall in half this now allows the seats to both fold up and the upper part 2 full down how upload a video here in a bit and fortunately it takes a while to upload
Here is a quick picture of the rear clips that I cut in half https://goo.gl/photos/uFFMUdJg2iomqTEx9
Picked this up on craigslist the other day new for $40.
Decided I wanted some color so ordered some vinyl and gave it a go this morning. Took two tries on the front but looks good. Rear was one shot. Not entirely happy with it as it does not seem to want to stick out at the edges. Looks good for now but I will likely peel it up if it doesnt peel itself.
You could try post heating it to help activate the adhesive and some edge seal
Used a heat gun when doing it. What do you mean by post heating?
Essentially what I did - Cut approximate size, removed backing, applied with 'thumb' pressure, heat with gun and pushed out all wrinkles, cut the edges, used vinyl tool to push down edges. Did the cutting and pushing all with the heatgun.
Tough to say if I used enough heat, maybe it just needed more or if I used too much. Certainly with a few more tries I would get it and I have plenty of vinyl but it was starting to get a bit windy.
Color matched the Z71 grill emblem.
AB5097A7-CAC3-498A-A206-76E495441C53_zps
0C18C369-586C-4B42-AF8E-FA77F3D5516B_zps
C1B66082-5A47-4759-BF83-2CB1A06CA4DE_zps
Painted my running board gap fillers with spray can bedliner.
7B1BEE16-959E-4050-B0C6-624AB8A458C7_zps
50B8D3D5-2BCE-428E-BFBB-E24DE2225A74_zps
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
