Doesn't look too bad, but the top isn't straight. Sorry, might just be my OCD and not saying I could do any better lol. I like the look of it both ways though.
Plastidipped the pillars. Not sure If I like it or not. What y'all think?
Before
After
I wanted not to like it, but I kinda do. Not sure I like it enough to do it to mine, but it looks good :ninja:
It is your decision, of course, but my preference is stock. I think the body-color framing of the windows gives the truck a much stronger look. When I see blacked out pillars I think of '90's Mazda extended cabs. This image of mine is not necessarily a bad thing but definitely not GM!
I added a Century canopy yesterday. I posted pictures on the topper thread but added this in case you haven't read that thread and are looking for ideas!
Edited by Donstar
Gave the truck a good wash and a coat of Pinnacle Souveran early today.
Nice choice on the wax [emoji1303]
Finally got around to running the wire from the back to the front. Also installed the power tailgate lock (still can't believe it doesn't come stock) and some backup lights that will eventually be work lights too via a relay.
Ran a bunch of extra wire too for future plans.
b3b6ee95b1f3fdabb59d6dd09546b2cf.jpgf980b60778ca4d9a4047d8e1a86f93d1.jpg3b1f5526a5a06c68584d7deb32e552ba.jpgf1f9726c54bc1bb52f87c1569da56a81.jpg0d85ff11ea1aacae5ed7afafe69a2839.jpg
Awesome mod !! I did this on my F-150 before I upgraded lol, thankfully it came stock on my '17 Sierra
Random question. Was under my truck for another reason. What are these two parts here on the exhaust? Resonator? 08842a857e6b7cc4209ee29e8ff239b7.jpg
Cat and flex pipe
i didn't really have to do much except drop my truck off at the dealership - but had the upper oil pan gasket replaced as it was leaking
thank you power-train warranty!
to be honest, i'm kinda surprised that this would be leaking in a 2014 truck
Been slowly piecing this together.
Stock head unit.
O gauge power wire to the back
8 gauge to the Amps.
JL Audio fix 82
JL Audio TwK D8
JL Audio HD 600/4 for the mids and tweets
JL Audio HD 750/1 on subs
JL Audio Stealthbox.
Still undecided on what I'll put in for mids and tweets.post-171808-0-09008600-1492870799_thumb.jpgpost-171808-0-41757500-1492870815_thumb.jpg
Remote bass knob
  • Like 9
Stock head unit.
JL Audio fix 82
JL Audio TwK D8
Still undecided on what I'll put in for mids and tweets.attachicon.gifIMG_0098.JPGattachicon.gifIMG_0099.JPG
Remote bass knob
How difficult was the remote bass knob?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,290 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
