LOL I apologise, I could not resist. I was just kidding..
Lol, so it is a spare battery, i didn't get it with my 2016.
LMAO! I was shitting bricks for this guy too. LOL!
Battery for your key fob?  Must be a dealer gift.
Dealers gift was giving us $4500 for a 2005 avalanche. Lol but ya bet they aren't the right size
Jrob - I went with the little Choetech charger off amazon for like $12.99. Took the black plastic casing to get to the actual charger on the inside and that lil guy fit like a glove right under the rubber and plastic in the console lid. I was worried at 1st that the charger wouldn’t be able to charge through the lil rubber mat AND that black plastic part of the console lid but it did. Took a 5/16 drill bit and BARELY widened one of the little holes (circled them in the pic) under the console lid to run the usb cable through. Works great and looks clean for the most part.
On 11/10/2017 at 9:52 PM, jrob56 said:
Which one did you go with? Got new iPhone too and want to do this as well in my console lid.
On 11/5/2017 at 8:23 AM, ChevyRoofer said:
Any pics?
Thanks for the info! Does this look like the one?
CHOETECH Qi Certified T511 Qi Wireless Charger Pad with Anti-Slip Rubber for iPhone 8 / 8 Plus, iPhone X, Samsung Galaxy Note 8 / S8 / S8 Plus, S7 / S7 Edge and Qi-Enabled Devices https://www.amazon.com/dp/B00C40OG22/ref=cm_sw_r_cp_api_6YncAbKBBGQSM
Yea man that’s the one. Guess the price went up a few bucks. But just peel the four rubber feet from the bottom of it,remove the small screws, and take that black plastic casing off to slim it out a little bit
Installed a wireless charger in my console this weekend.
I wont go in detail on the steps as most know how to do it, but when putting the plastic tray back in I used 4 screws to mount the plastic tray back in place. The tray does still sit flush, and has no visual difference or feel than when 6 screws were in. I have used this over the weekend, and it has easily picked up the phone each time it is set down, and remains charging as long as the truck in on.
Below is the charger I used. To access the wireless coil, there are 4 rubber feet on the bottom that you need to remove. This will give you access to 4 screws. Once they are removed simply separate the top and bottom and the coil will come out.
https://www.amazon.com/gp/product/B017KQXO4U/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
that's funny, I just did the same install this weekend with almost the same charging mat on my 2014 sierra.
the one below is a similar model and also works.
https://www.amazon.com/Choetech-T513-Wireless-Charging-Devices/dp/B00JA7HNZO/ref=pd_cp_107_3?_encoding=UTF8&psc=1&refRID=A403PGZ2CXVSJV21119C
Installed a 22" light bar from Amazon this weekend. Mounted on the two brackets that were from the lower valence that i removed. I had to add a 24" piece of aluminum behind so it was mounted to the holes since they were only about 15 inches from each other. It fits perfectly between the two tow hooks too.
0ac32c5c8d6c3e8e7cb9c5de095572f3.jpgFinally finished out my headlight and fog light switch up. Like I said, I went with Alla LEDs for both. Output isn’t bad. Haven’t had the opportunity to use the highbeams that much but it’s a definite improvement.
Edited by FootballCoach53
Did you remove the entire air dam or just the bottom ~1 1/2" piece? I know you said lower valance just wasn't sure exactly how much you took off. I like the idea and location
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 2,143 Guests (See full list)
