19 minutes ago, bkesting said:
Great mod.
Any reason why you went back to stock cluster?
Hes getting more new goodies ;)
29 minutes ago, Frankielozano214 said:
So with that upgrade I can add heated seats? Bad ass ?? ?
Sort of.  Adding Factory Heat requires 3 things.
1.  Heated Seats
2.  Wiring
3.  BCM Programming
With regards to the wiring, we'll have to validate what your truck has present and/or what is absent.  The heat/cool module lives under the front passenger seat.  There are circuits that go in/out of the front seat and hit the driver seat, BCM, fuse panel, which buttons.  So we have to validate what all is there.  Determine with needs to be added.
Once all the wiring is present, the last piece of the puzzle, is the BCM programming.  There is a data circuit in the BCM that communicates to the heat/cool module.  This circuit is not enabled.  So even if you add all the wiring, you'll have to get the BCM programmed to enable it.
So for anyone serious about getting factory seats functional, we can go down the path of the needs.
47 minutes ago, bkesting said:
Alright......spill the beans! :)
Working on adding Factory Trailer Brake.  Trailer Brake signals filter from the switch, through the cluster, and a trailer brake module.  So these items with WAMS now getting evaluated for integration.
No, mine are heated but are cloth from the factory.
Not as bad as it looks hardest part was taking the airbag out and wondering if I was missing wires n my radio area so take pictures of all your wires while they are plugged in
Once u figure out how to remove the airbag it’s simply, now that I know how to take it off looks badass tho especially when your friends have the plastic black dash ?
I put a Hopkins insight brake controller on mine today. I didnt want the typical knee buster one, so this fit the bill perfect.
I've seen a few people install their "knee knockin'" brake controller in that spot too.
I have seen a couple there, but they usually stick out a few inches. Should have just bought the dang max tow and had the factory brake controller, but a max tow 6.2 z71 was hard to come by.
5 hours ago, shadrickjm said:
Bought a set of paintable tow mirror caps.  Just need to color sand and buff them out.
Garmin Fenix?  Nice!  I have a 5X Plus.
  • Recently Browsing   1 member
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,634 Guests (See full list)
    • I have 2 choices.
