What is the emblem above you OEM Silverado door emblem?
Sent from my crappy iPhone 6
using Tapatalk
I think it says "True North"?
"True North" just a package us Canadians get. It's getting removed
We get the Texas Edition down here!
Got any more information you can share about this? I like the look and would bet this is better than the stock lights.
You bet! Heres a thread I started on the subject. The first post on page one has the link to the seller and if u read thru the next couple pages, i have kept a running update on the whole deal. The last page(s) has my review and is loaded with pics. Please feel free to ask any questions... Just remember STAY AWAY FROM THE REPLICAS THAT USE THE H1 LOW BEAM BULB! THOSE ARE COMPLETE GARBAGE. ALOT CHEAPER, BUT GARBAGE. These use the same H11 bulb as factory and are the ones you want
http://www.gm-trucks.com/forums/topic/179308-what-about-these-ltz-projector-headlight-replicas/
Edited by dbcooper748
I could get a Texas addition here in VA as well lol
Just installed dual Rigid leds. One DOT version and one spotlight in each side. The dot is wired in the factory fog light harness with an h16 to deutsch jumper harness and the spotlight is relayed in with a trigger wire coming from the high beam.
sent from my Samsung Galaxy S6
Edited by dkweeks
  • Like 3
Any details of the install? And how much did it run ya $?
And anypics of the whole front end with these installed?
About $340 for both sets and another $20 for the jumper harnesses. I have been watching amazon for a few months waiting for the prices to drop to an "acceptable" level.
Nice! U happy with the performance ?
You have to see the dot lights in person. They have a very defined beam. They are way better than the factory fogs. I will have to do a better job aiming them and the spots but that will be tomorrow. Too busy watching football tonight.....
Washed it with eco-smart in the garage today.
I like that switch location on the light bar I might have to do that.
Sent from my HTC M9
Purchased some AMP Steps from a member on here last week. Finally got a chance to install them today. I ended up cutting off the lights that came with the steps and putting some better/brighter ones I got off eBay. Very pleased with the steps and the upgraded lights!
  • Like 5
I knew you'd like them! And I really like the white light vs. AMP's purplish LEDs
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
