painted the honeycomb parts of my grill today.  the paint color was "stainless steel black" and it looked like a metallic black on the can.  After painting it was lighter grey metallic, but I really like the color so I'm probly gonna keep it.
  • Like 6
Looks good. I just painted my honeycomb grille satin black and it looks like a different truck. Actually have started to like the 2014-15 front ends better if they're done right.
Sent from my SM-N950U using Tapatalk
That's the look I was going for, just got tricked by the paint can lid.  That looks great! too much chrome for my taste the way it was before
just ordered a retrax proMX for mine...
decal overlays, saw it in a post in this thread somewhere but can't remember where.  Need to find "Texas Edition" decals if someone know of a place.  Also have a custom dent in the rear bumper..IMG_3102.thumb.JPG.5813b59d531c57a6f83a4b04c5871e8d.JPG
  • Sad 1
On 5/21/2018 at 7:22 AM, PotvinSucks said:
2in RC level, added 305/55/20 Toyo OC A/T2s and finally washed the truck. I have a little rubbing at full lock on the carpet fender lining but so far so good.
Are those the stock 20’s that have been powder coated?
They are probably just the stock 20's. They come black from factory now.
@nolabell what ^^^ said. Technically yes, they are powder coated stock 20s, but they do it from the factory now on both the GMC and Chevy side. I'm a fan lol
[mention=140532]nolabell[/mention] what ^^^ said. Technically yes, they are powder coated stock 20s, but they do it from the factory now on both the GMC and Chevy side. I'm a fan lol
Yeah it looks great. I have a 2014 with factory’s 20’s in chrome. I plastidipped them about three years ago and they are showing signs of wearing. I like the look of powder coating but haven’t gotten any estimates on that option.
Just got my Leer 100XL topper installed last weekend.  Went with the removable sliding front window, electronic lock, and tracks for a future roof rack.  So glad I read up on here about toppers before I bought, otherwise I probably wouldn't have went with the removable window.  Was on some dusty roads this weekend and I was surprised how much dirt collected between the cab and topper windows.  So nice and easy to just remove the window to clean.  I'm loving it so far!  LED strips going in this weekend for interior light.
On 5/21/2018 at 5:05 PM, pgamboa said:
Have not had a reason to get that far into the seat.
Man.. do you ever drive that truck???? lol... every post i see from you homie , its torn into peices!!!!
  • Haha 1
It SUCKS driving without a center console.  I can't tell ya how much i depend on cup holders.. LOL
If you go on eBay, they have decals all over for which ever your looking for.
I agree.  Plus the jump seat cup holders were smaller so, you could only fit certain cups in them.  The new full center console fits so many different varieties of cups.
Is it the shadow(s), or is the shell just a touch too long?  Looking at getting one for mine.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
