2014 5.3 Oil Question
Yotaman
Between question...when do I go to the dealer to have this done? Noob question but I've never had a "warranty" and "4 free services". I'm currently around 75 with 3500 miles. Sent from my DROID RAZR HD
Aaron: Back a few months ago, the dealers were saying that you had to wait for the oil life monitor to say you were down to 20% life. Now I'm hearing on this forum that you get four changes, whenever you want them, but you're limited to four free changes within the first two years. I'd suggest giving your service department a call to clear it up.
Getting down to 20% usually puts you right around the 6500 - 7000 mile point.
What is the rule with changing your own oil and keeping the warranty going? I figured a dealer or shop would have to change to give you a record. Could someone fill me in?
You can do it yourself, but keep receipts for the oil & filter purchases and keep a record of when you changed it. As long as you have a record of the date, mileage, and what you did, and corresponding receipts for the purchase of the supplies you'll be OK.
Roger that, thank you!
This website has a list of Dexos1 approved oils: http://centerforqa.com/gm/dexos1-brands
Sometimes you see oils that will say they "exceed Dexos1 requirements". From what I've read, GM charges a royalty fee to have Dexos certification. Some companies oils meet the spec but they don't want to pay GM the royalty fee to advertize that they do (hence the "exceeds Dexos1 requirements").
Just called my Dealer and talked to the service department said I get 4 Oil changes in 2 years, can use them at any time.He sugested to me to wait until 3 thousand because they also rotate the wheels.I have almost 1000 on my truck now.He also said the new engines are different then years ago when it was recommended to change the oil at a earlier time.
I think it varies by dealership. My dealer says GM should honor free oil changes within the first 2 years, unlimited times as long as the OLM gets below 30%.
Seems to be that way (vary by dealer or whoever got which memo). Even at my dealer, the Service Manager told me one thing and Service Writers were sying another. I think they all sync'd up though. At my Dealer, it is only 4 oil changes / tire rotations during the first 24 months, but whenever customer wants. I run very low mileage so I will do mine at 6 month intervals which is usually 2-3 kmiles. Just my circumstances.
I'm actually around 57% @ 3300 miles. Perhaps I'll call service and schedule one ... You'd think with all this fancy technology, I'd get a text message that says "your oil level is at xxx, please schedule an oil change". Sent from my DROID RAZR HD
According to my service guy, 20% was the point that an oil change was necessary (and it would be close to 7000 miles), and there was no need with the synthetic blend they use to change it sooner. I understand that some people still insist on changing it early, and especially make sure the first oil change was done sooner.
So at 57% and 3300 miles, you're probably right on track, and according to the manufacturer, still have quite a bit of life in the oil. So you'd definitely not receive any kind of warning from your vehicle that you're due for service. I got down to 19% and 6950 miles before my first oil change. And I got no messages.
I think OnStar has a maintenance program that monitors your vehicle's systems and can send some type of message, but I don't know how often that happens, or how they send them to you. (I don't use text messaging, so I wouldn't have gotten a text from them).
The one VERY IMPORTANT thing for you to do is to check your oil regularly and keep it topped off with the proper oil. My dealer said it would be acceptable (to GM) to lose 1 quart every 3000 miles. I haven't seen this oil consumption in my truck, but there have been posts on here about oil loss so it's important to check.
In my opinion, as long as your oil level is good, you're still in good shape.
You have a low oil light and a oil change light, whats the other light you want? People change their oil at their own whim. So I guess you want a mind reading oil change light thingy. LOL!
Onstar Does this....but you get an email and it gives you all the current stats of the truck.
You will....from your friends at OnStar. (at least I do, for all my OnStar equipped vehicles)
Mine is still active until June. It'll notify me "time for oil change"?
If it was given your email when it was setup, you should get a monthly maintenance/vehicle diagnostic report from 'OnStar Services'.
It's a neat way to keep track of the status of the vehicles you arrange/do the maintenance on, but don't drive (or not often).
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
