Just FYI for those of you wanting methods and can't decide 17" or 18". Check out Graydon Motorsports on Instagram. He's running 18" methods with 34's and a confirmed no rub on King coilovers. Only reason I went 17" is I like the big tire look and wanted them flush with fenders.
There is also a small aesthetic difference in the 17s versus the 18s. I can't remember who it was on here that has 18s on a silver sierra but he noted the 17s are more concave than the 18s.
Posted a few months ago. I'll post again since I am so happy with this thing.
Fuel Maverick 20x10 -20 offset
305/55R20 BFG KO2
3" maxtrac level on front / stock on back
*Slight rubbing when reverse at full lock.
A0E062F6-6111-42F5-A799-E55A82278614_zps
F8B0977B-B8CF-4693-A9F6-240F44804765_zps
60C9F968-7BE1-4B52-BC3A-448921CE3E0C_zps
Looks killer man! How's the ride with the 3"? Do you have stock ucas? I have a 2.5" on mine but I'd like a little more to get a slight lean going on
Thanks buddy. Honestly ride feels the same to me. Occasionally feel the difference on bigger bumps (stiffer) but otherwise feels the same the majority of the time. I do have stock UCA's. I'm happy with the 3" as my truck looks exactly leveled.
Edited by Boltman21
Has anyone ever put an led light bar in a stock 2015 silverado bumper?
Do a search of the forum, there's a pretty extensive thread about light bars.
Just got my 20x12 hostile Strykers yesterday.
Good looking wheels
305/55R20 BFG KO2
With a 3" front level and stock rear block, isn't it a little higher in front than in the rear? Or is it exactly level?
I HAVE A 2 INCH LEVEL WITH ZONE 1.5 BODY LIFT. CAN I FIT 275-60-20 TIRES ON THIS SET UP WTIHOUT ANY RUBBING?
Yes. That size will fit on a completely stock truck, so you'll be just fine.
I went with the 3" because I still wanted to fit in garage, I have a 7' door and i still have about 2" to spare. thats also on 35's
Good to know! Thank you!
Yeah the 3" looks great on yours. Mine looks to have a slight rake with the 2.5 I'm definitely gonna add another half inch or remove the rear blocks still undecided
305/55R20 BFG KO2
Boltman, do you have a side shot. I have a 3 inch as well and your stance and the way the wheels sit is exactly what I'm looking for. Curious to see how much tire is past the fender
Sent from my Nexus 6P using Tapatalk
305/55R20 BFG KO2
Looks really nice
    • I imagine the cold winters up here with repeated short runs in town every day for those that live and work in town and given what I have come to learn on this forum with DI engines having fuel dilution issues, and if they don't change the oil until it says to but keep driving it for a while, I bet all that is just lovely on those finicky lifters.
    • I just did some reading and Stabilitrak is more than a what I had originally thought. It is more of a vehicle control system to help the driver in precarious situations. I thought it was only the AWD system. Now I know. So I changed the title for this thread to AWD conversion to Z71
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
