No comment, we have steered this thread right into the ditch....
No ditch from me, you? Lol
Sent from above
Guy/Gals..  I've searched already.  Just looking for confirmation and not condemnation.
Just bought a 2016 2wd extended cab with 16k miles.  Beautiful truck...with zero lift or level.  For right now I need to fill up the wheel wheels just a little better than the stock wheel/tire combo.   I want to go with a 20" wheel and a larger tire.  From what I've read, the 275x60R20 might fill the hole and not rub...but at what wheel offset?
I'm trying to move up to a 9" wide wheel from a stock 17x7.5.  Maintaining the 31 offset of the OEM wheel puts the extra 1.5 inches on the brake side.  It would seem (although I'm a newbie) that I'd be better served dropping to a +18 or +12 offset to better "balance" the width and avoid rubbing inside or outside.
Anybody with experience or knowledge...give me your 2 cents.  It might save me a few hundred bucks...
I did the +18 20x9 and they still rubbed, I’m very happy now with my 20x9 +1 offset zero rubbing
Sent from above
Sent from above
Where are you guys rubbing at, mud flap? And how bad?
Does anyone else have problem with only rubbing one side?
My rubbing was the uca and liner while backing up.
Sent from above
Sent from above
Sent from above
Control arms and rear felt liner only when backing up
Sent from above
Sent from above
I see. Good thing I went with -12 instead of +18. But yeah I rub on the passenger side only. When in reverse. I have like 1/8” on the driver side. I wonder if that’s normal....
Everyone’s Suspension moves one side during backing up. Recommend strapping back liner or I’ve heard heat gun will do it too
Sent from above
    ncleg
    ncleg
  • Who's Online   3 Members, 0 Anonymous, 1,221 Guests (See full list)
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems.   True story. One winter day no long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses more gas. She finally got unstuck spinning in 2wd.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
