Just note that my tires are 12" wide, so if you use 12.5" wide tires it will stick out a little bit more, also my guess is with -12 offset and 12.5" wide tire you will need to do some trimming on the well liner.
you so helpful... thanks again.
I did not notice you had 12" tires. so that will add another .25 outside when I use a 12.5
Wonder if I can get like a +6 or I could get a +1 and use a .25 inch spacer if I want a little more.
I have never seen a -6 offset wheel, but it depends on the brand name, but I think you will be happy with +1 and 12.5" tire, and if not you can try a spacer later on, cheers.
Hello, new to the forum, here is my set up:
18x9 Fuel Maverick +1 offset.
Goodyear Duratrac 295/65.
Rough Country 2.5" leveling kit with 1" rear block.
No rubbing at all, love it.f7c602a48021d64c795a2988befcace4.jpg73951ca2ae29d26d35ba70cd9fc802a3.jpg
Can you confirm your offset? Nothing trimmed?
And can you by any chance take a pick of the wheels turned fully both ways and show where its closest point is?
I know your not rubbing, but how close is it?
I want the +14 offset with 285/60/20..little taller but little skinnier.
Hi, yes offset is +1, in the front there is like 1" clearance and about 1/2" or less in the back of the well liner.
Front well liner
Back well liner
Depending where you live, farther out can be a nightmare for throwing shit up the side of the truck.
I have a 0 offset and bushwaskers and kick back mudflaps and it seems to be the perfect fit.
Alright everyone, fixing to order some 20x9 fuel mavericks for my silver 2014 with 2.5 RC front only level. Going with a toyo tire. Give my your opinions: 295/55 mt with+14 offset or 305/55 at2 extreme with+20 offset? It's hard to not go with AZGMCZ71's set up on his silver!
What are you guys doing for TPS when you go to aftermarket wheels?
I'm getting my new wheel/tire setup installed tomorrow. I'm having my factory TPMS sensors swapped over to my new setup.
Im sure everyone is moving them, it super easy. You don't even have to dismount the tires.
Shop that is mounting my new tires will move them for free.
You sure you dont have to pull the tires off the rims? Im gona buy new sensors
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
