Depends on engine/trim.
Battery, heavy-duty 720 cold-cranking amps/80 Amp-hr, maintenance-free with rundown protection and retained accessory power
1 - Included and only available with V8 engines.
Battery, heavy-duty 730 cold-cranking amps/70 Amp-hr, maintenance-free with rundown protection and retained accessory power
The 730cca/70amp-hr is standard on 2014 wt and lt with the 720CCA/80Amp-hr std on LTZ/HC optional with v8 on wt/LT.
Why do you want to do this? What did I miss?
You need to match your batteries at the same size(cca) so that they charge / discharge evenly. If you put different sizes in it can possibly cause problems.
If you have a battery isolator/charging circuit, you don't need to worry about matching the batteries. I had this system on the 2008.
http://www.painlessperformance.com/webcat/40120
You can add a heavy cable and solenoid to this system and use it to "jump start" if your main battery rolls T.U.
Edited by spurshot
Complete guess, but I think the engine compartment will be/is the same for the 2015 2500/3500 trucks and they have 2 batteries (diesel), cost savings. same engine bay, no extra battery on 1500's. As far as adding a second one, a waste, unless you are adding a ton of lights, subs, tv's and aftermarket accessories. and then you'd still need a bigger/extra alternator to charge it. Or, spare battery for worst case, battery dies in middle of nowhere. Not really any reason IMHO.
I like 2 batteries for trips. Sometimes, I get pretty far from civilization. A functioning battery is a critical piece to the function of the truck. Having redundancy of the battery is more than just peace of mind. It can save you life in some situations. My brother recently had to use the second battery I put in my 2008, after the main died. I don't think he was in a life threatening situation. But, it can happen pretty easily in the back country. At the very least, it's extremely inconvenient to not be able to start your vehicle 20 miles from the nearest person.
Edited by spurshot
So carry a jump pack...
I'm not familiar with them. Are they lithium battery packs?
I bought the Antigravity micro jump starter a couple months ago. Haven't had to use it yet to jump a vehicle, but I definitely love the compact size. Its only a bit larger than an external hard drive and fits nicely in my backpack. And since i'm always on a plane or tour bus, I always have a back up way to charge my phone or laptop
Edited by gSwift
what do you guys think of running this Power-Gate Dual Rectifier Isolator and using the 2nd battery to run other accessories with a relay/fuse box like OEM designs?
http://www.perfectswitch.com/isolators/dual-rectifier-isolator/
I plan on having a winch up front and rear, a 30"-40" light bar in the grill, dual 10" light bar in the rear, or J.W. Speaker model 61xx series lights in the rear to aid for extra lighting, probably will do an air compressor eventually, and not sure what else in the future.
Edited by henrypbui
Henry
I was thinking along those lines myself. Not so much the winch, but maybe. But power sockets in the bed for portable refrigerator, compressor, and any other stuff like that.
Painless has some fuse blocks I was looking at.
You might give some thought into the ground circuit, since the #2 battery would be isolated and not in parallel. I'm suspicious isolated batteries don't want to use a common (chassis) ground path. It might play badly with electronics.
  • 6 years later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
