K&N filter replacement.
Dmendrin
I bought the K&N slip in replacement today for my 2014 Silverado. One major notice was the depth in the stock filter compared to the K&N. The K&N filter is much smaller in depth. Have any of you purchased one and notice a difference in anything? Or did I waste my money? If so or in general, how do you like your cold air intakes?
Stock filter is thicker cotton style meant for lasting higher miles and meant for stopping more dirt for offroad.
Any replacement drop in ive purchased has always been less in depth.
After seeying the benefits from changing the whole intake tho i now go that route on all my vehicles.
Take the K&N and bandsaw the ends off, then unfold it. Hold it up to the sunlight. You can see thru it. Unfold the stock filter and compare the filtering area. I think you'll find there is about 4-5 times the area.
You can push a proverbial rock thru a K&N. I found fine dust inside my intakes over the years of running them. Never again. Good luck.
I have never had an issue with K&N. If you buy the MIT from airad (the tube). Their filter is like the K&N. I have ran a K&N on my supercharged Z (130k miles supercharged) with no issues.
About time I agree with something you've said. I've used K&N filters before and they are junk, they compromise filtration for supposed HP gains. If you want a good filter, see if AEM makes a filter for this truck, I recommend that brand.
I agree that the AEM is a better piece. However...it's still a K&N.
Back in 'the day', the Green Weenies were really popular with the off-road cars and bikes. They were low restriction. But they didn't filter for squat.
do you just run the stock filters?
On ny mobile, so can't see what truck you are running, but the Z71's already have a high capacity air cleaner.
If you want a better filter you never have to clean get a Donaldson powercore. Volant offers them with some of their cai. Also get the pre wrap.
All cars and trucks come with cold air now, if you want the noise change the tube.
While they the stock designs are setup to pull from a insulated area, they give up power due to small opening and from having to comply with NVH requirements. The larger opening on the aftermarket CAI systems will always make more power of the stock ones and not sacrifice the air pick up area.
I have ran K&N filters on my vehicles for well over 500k miles, my dad has a K&N drop in filter in his 1996 Yukon with over 500k miles on the clock on the stock motor, so the posts about the "inferior filtration" mean nothing otherwise we would be seeing vehicles on the side of the road everywhere. Any dust that does make it thru the filter will be consumed during the combustion process, plain and simple.
"consumed", not so much. "Make it through without any detrimental affects", most likely.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
