That's great Ive read through a lot of post and it's mix reviews on if they rub or not. Kitchener Waterloo area
Got mine today
Ryan
Looks good, I have also noticed the ko2's seem to be wearing a little better then the previous version too.
what size are those ryan
275/70/18
Ryan
Blue and pink skid mark?
Kids playing with chalk
Ryan
9510976ae0c406df56a6a92e093371fe.jpgab18cbaa0fbb1b15c8679b925ba6ffd9.jpgcbe116d2e4dd8de8cda32cdd62ec7e6b.jpg
Love these tires, extremely quiet on the highway and great off road
nice! I found these tires as quiet as the stock good years on the highway. The only increase in noise I can find is around 20 -30mph .. but it's not much
Huh, that isn't what I heard. Riding in a co-workers 14 SLT with them they were much quieter than a mud tire but highway tire quiet they were not.
Tyler
I agree. I hear them on the highway whereas the stock sra's were silent. I have an LTZ that is otherwise stock and the truck is quiet but the KO2'S do make some noise. It's not awful but it's there. Price I pay for running shoddy roads that eat highway tires.
Sent from a potato
Edited by 1994Vmax
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
