33 minutes ago, Kurtj29 said:
PM sent. Looks great. I am interested in your Denali grill. I have been going back and forth between doing a black out Denali or the standard grill. I purchased an SLT grill and was going to wrap the chrome surround. But lately have been looking to do a blacked out Denali. Thanks for the pictures.
Thanks. Replied to your message.
On ‎12‎/‎4‎/‎2018 at 8:47 PM, Kurtj29 said:
Good looking truck, where was the picture taken?
I usually do a full detail when I get a new truck but haven't had a chance yet and the NH weather has been crappy, but I picked up my 2018 Silverado LTZ on Thursday this week.
I'll post better pictures once I get it cleaned up a bit.
Thanks, the picture was taken at Keechelus Lake up at Snoqualmie Pass, Washington.  Just take the service road out past Snoqualmie East.
Approximate location:  (47.3767460, -121.3887877)
Edited by Kurtj29
Kind of thought it was up at Snoqualmie, you can see all of the stumps in the lake behind your truck. Wife is getting heavy into photography, so we have been going up 410 to Crystal, snow is piling up pretty good.
57 minutes ago, CruseMissle said:
All-Terrain in a little snow
Great picture!
Edited by Kurtj29
Went out in the rain on Friday and got a couple of shots.  Trying to make something out of the cold dark winter day here in the Northwest.
0666FE5B-EE73-40E0-8E81-A877A6090F03.thumb.jpeg.43bde476a7713cf5c1a34a2c8f69c382.jpeg82A33821-A489-4381-8266-595F2E37E295.thumb.jpeg.117e46b06b5c7ff6774669b9b854783c.jpeg
Edited by Kurtj29
That is a great photo of a good looking truck!
Good looking shots of the truck, espically the bottom picture.
First time post, I've been watching this forum for years.
2018 GMC Sierra SLT.  3/1 lift, 35 inch Toyo Open Country tires.  T-Rex black grill inserts, then popped on a Z71 emblem I bought on eBay.
Installing ICI Magnum RT steps next week.
Any other ideas?
Any other ideas?
Welcome, nice looking truck!
5 hours ago, slj2008 said:
Welcome -  Window Tint (if you haven't done it) .
I haven’t.  Front and back windows or just front to match back?   Rear window?
On 5/6/2018 at 8:02 PM, RK44 said:
FInally got the ARE overland cap w/yakima racks and bedrug installed.  Mods include Fuel Maverick 22x10 -24 offset, Terra Grappler 285/50/22 (33.26"), ICI magnum RT steps, Black Horse Grille Inserts, 20% tint all around and a 5% brow.  Motofab 2.5" Level/lift and Zone 1.5" body lift, husky liners on rear wheel wells.
How are you liking the ICI Magnum RT’s?   If you had to estimate, how far are they mounted from the rocker panel?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
