From what I read in the thread the airbag is different. But my guess is something else is different since gm has a different part number.
From reviewing the video from Tinkering Fox, his wheel only has 1 air bad sensor in his 2500. In my 1500, I have 2 sensors.
Yeah, the 2500 clock Spring has 1 wire hookup, the 1500 has 2.
GM has changed even the 1500’s Part number haven’t they.
So other than the air bag it looks identical. I suppose no one has gave this a try yet.
I’m curious to, and you can’t ask the dealership, they say none of this stuff can change. Thanks
Pgamboa
Would’nt that be corrected with the 2 wire Airbag Clock Spring for the 1500 ?
Using the 2500 wheel and 1500 clock Spring
you think?
I think if your wheel only has one clock spring input, it might throw a code if your original wheel came with 2... I’m not 100% sure.
On 7/11/2018 at 11:18 PM, pgamboa said:
For anyone that is performing this upgrade and finding that they don’t have the clock spring mate down in the footwell to plug into, or they have they the mate but it’s not hot, here is a video I made showing the harness I’ll be making and will be available for $25, Shipped anywhere in the US.
Enjoy!
I looked under my dash, and I have that connector shown in the pic.  I can test whether it’s hot right at the connector correct, or does it require me to take the side panel and check for a fuse and more? Sorry....noob question. Ty Phil.
No sir. Just start your truck and measure those pins for 12-14VDC.
Thank you sir. I’ll definitely be checking for this. I wonder what determines which wires are connected or not?  I know of something is special ordered, but it seems arbitrary that some have certain connections and others don’t.
I wonder if anyone has any knowledge as to
the 2500 Steering wheel having the heated  wiring
present,such as a lot of these trucks having the plug present for the heated wheel,although some are hot, but some not?.
Oh also, want to give a huge Thanks to Pgamboa & others, whom have made this upgrade possible with their help and sharing.
I am not sure on this. I only follow the truck forum and not the SUV forum.
I’ve got power coming from that plug ? 13.5 v dc
I can’t take credit for this,but thought you all might like to know.
From a GM tech:
Concerning the Difference between the 1500 & 2500 Steering Wheels:
It’s the Weight Dampener, it comes off in 10 seconds by pushing out from the rear side,it’s not an electrical part. It is designed to minimize vibration on the lighter trucks that come up the steering column. The heavier 2500  trucks have more weight and don't require. We plugged this into the 1500’s Clock Spring with heated wheel, success,No problems, no lights.
Trying to post pictures for you. That's all you need to do to add this component onto to make the same as the 1500. it was an easy change over. Remember to use the 1500 Clock Spring With Heat.
ok, Having trouble post pics.
When the weight dampener is added, the 2500 is the same as the 1500’s.
The reason for the different GM part numbers.
On 12/23/2014 at 12:57 PM, PMattras said:
I never had a heated steering wheel and don't see to care about it. Just another thing that will give you trouble later down the road. What is the cost (material and labor) and time to put it in?
I'd never had heated seats until the 2008 Rav4 we had some years ago.  I thought, pssh, that's silly and just more crap to go wrong.  Tell ya what, when the first winter hit after getting the car and it was -17 out, I popped those seats on and thought "heeeeeyyy...this is niiiice."
Then later we got the 2014 Grand Cherokee which had heated seats and heated steering wheel, and I thought "Pssshh...heated seats, great, but steering wheel, meh.."   Then the winter came and after clearing snow off it and climbing in with frozen hands, I grabbed that warm wheel and thought "heeeey...this is niiiice."
I made damn sure my new Silverado had the heated steering wheel and the heated AND cooled seats.  Turned on that seat cooling and heeeey...it's niiice!
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
