I installed 5100s in my last truck. 2004 Nissan Titan 4x4. I installed them on the highest setting. It leveled the truck very nicely. Though I never had any problems with the shocks or components.....it definitely made the ride pretty harsh. I got use to it after a while. Even drove across the country with it. Bumps in the road were harsh though.
I'm contemplating if I even went to mess with my 2014 Silverado. I was thinking of leveling it or lifting it. Only it rides so nice and smooth right now. I'm not sure I want to risk messing that up. Lifting the truck would make it look great, but using my truck for work and loading quads in it would make a lift unpractical for me I think.
Honestly if you have a truck with the black z60 shocks, a leveling block really doesn't change the ride much at all. Believe me, I'm a bit of a nut with suspension, I've had three different sets of shocks on my truck. My friends black z60 shocks ride really nice, with little to no body roll. We installed a 1.5" level block in his and it still rides nice, left a little bit of rake so it doesn't look stupid when he has a bit of a load. Cheaper and easier to install, and if you don't like it then you take them out and sell them.
Edited by projectsummit
Haven't seen 6112s offered for purchase anywhere. I'm going to hold out for those and 5160s for rear.
People may read this and get confused..........Shocks don't actually give your truck any lift, that's not how vehicles are lifted. Only the adjustable ride height 5100's allow lift by moving the snap ring to set the perch height. There are several brands out that allow for increased ride height by having the coil spring set higher up on the shock.
Shocks alone will in no way lift a truck. The rear 5100's are not ride height adjustable and do nothing for the rear ride height. They are simply a direct replacement for OEM shocks.
Chas here, previosuly posting under the other TotalAuto name but lost the password.
Its more confusing when you put it that way I think. The front 5100 ride height adustable shocks have different preset lift levels that will bring the front of the truck up while retaining factory springs. No other items than the 5100 front shocks are requried to lift the front. While most shocks will not lift a truck up, these will.
The 6112's won't be available until the end of the year. I hope they will be the answer to a good ride since they will come with a softer spring.
It is now looking like end of March / early April before we see any Chevy/GM applications from the 6112. The 5100 is a great option for the time being and for those just looking to bring the nose up. They are a big upgrade from stock. The 6112 is in a different ballpark when it comes to ride quality and offroad performance tho.
We will be the first to offer them when they come out, like we were for the Tundra, Tacoma, FJ & 4Runner models. We will post up here first when they arrive!
Thanks
Per Bilstein "I can tell you that the domestics are turning out totally awesome. I couldn’t see anyone buying anything else for these trucks. The 6112 transforms the GM into a completely different vehicle… it’s crazy!"
I called Bilstein this week and they said they wont be ready until early or mid next year :-(
Got tired of waiting and bought Fox 2.0's. Now trying to get them sorted out to actually give me 2" of lift as advertised.
In my last truck I installed 5100s on the highest setting. It leveled the truck out great. The ride was pretty ruff at first. Idk if I got use to it or the shocks wore in a bit.......but it seemed to ride better as time went on. Only, when I went off road with them they seemed very stiff and my steering wheel shook/ jerked pretty bad. The whole truck shook/vibrated. I had taken the truck off road prior to installing and it rode much better with stock shocks. I think the the highest setting might of just been too stiff.
I've been thinking of leveling out my new truck, but that experience has me thinking I'l save up andl try fox. . Has anyone else experienced this while off road with 5100s on the highest setting?
Ok ladies and gents. I need some help on which setting to use. I have a Crew Cab 6.6ft bed with a Leer shell. Right now with my stock 17" wheel and tires the front lip of fenders are close to 36" to floor and the back lip of rear wheel well is 38" to floor. I do not want the rear to be lower than the front and I plan on installing the Air Lift load lifters out back in a few months. knowing this should I just go all the way to the 4th notch for the 1.85" lift?
What do you all suggest?
I have the 5100's sitting in the garage, but cannot decide on what to do. Im thinking I might go with the air bags in the rear eventually as well. I also dont even need the extra lift in the front with my 275/70 K02s, thought I would which is why I bought the 5100s. Totally cannot make a decision
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
