2 hours ago, ESSGUY said:
thanks for the reply, i think i will set bilsteins at 3/4 in front, truck is not a daily driver and when it is used it will be either loaded with hunting equipment and dogs or towing 4 atv's.
Tandem axle? You'll have no issues
 Here's a better front shot with a decent load in the trailer (16.5' steel chassis tandem axle) there are 2 snowmobiles in the trailer at the time.
yes, tandem axle aluminum. pulls nice and has good tongue weight.
Wow.. hauling my 16’ enclosed on all stock suspension no leveling or drop I already sag.. I want to go to 5100s and level but would definitely need air bags. With the factory rake and my trailer hooked up I’m already a little lower in the back.
I've seen them listed as available within the last few days so they must be out finally.
I'd be amazed, but I'll look before I order something this month. Thanks for the info.
I have seen they posted on their instgram account that the 6112 is available.
Doesn't show on their site, so ordered 5100 rears. I'm over them and can swap them quick. The fronts will wait for when I do all my front lights again, just make a weekend out of the front.
For the Tahoes...I don't see 1500 anywhere...
Will 5100s help my back from sagging so bad with my trailer?
The 5100 rears are just shocks. No lifting ability. I will tell you they help with towing quite a bit as far as the bucking and side to side bouncing. They may lift the truck 1/4" in the rear simply because they have a lot of gas pressure extending them.
If you want to solve your sagging rear when loaded and towing get a set of Roadmaster helper coils. They install quick and are adjustable for the weight you want.
Even if they don’t lift I think I still want them. I’m coming from a 3/4 ton and my first time pulling the trailer I noticed a ton of what felt like chassis roll. So if they help with bounce, roll and sway I am sold.
I think 5100s out back AND a sway bar will make you happy.
Check out the Helwig rear sway bar, it made a HUGE difference for me. https://www.summitracing.com/parts/hel-7735
Edited by aaronarf
Okay, now that I've had my '17 for 6 months I am wanting my raised height that I had in my '15 or somewhat similar. I had the front of a 2.5" RC leveling kit, but switched out the rear blocks for 3" ones, as I was able to keep most if not all the factory rake on the truck.  I am looking to put Bilstein 5100's all-around this time to stay away from the spacers and wanted to know how much if any rake is had with that setup? Am I going to need to put in 2" blocks to raise the rear a little more over the 1.25" factory blocks? I also have Hellwig helper springs to help with towing the trailer.
TIA.
TIA.
I have a slight rake on my truck, Bilstein 5100s set on the highest lift and factory block in the rear.  It isn't excessive, 2" blocks would definitely give you a substantial rake, IMO.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,226 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
