9 minutes ago, Battle Born Offroad said:
If you are using the standard 0-1" 5100 for the 1500s and that block, you are limiting your travel by a bit. It will work, just realize the shock is being stressed at full droop pretty hard.
So I should opt for the 5160's then ;)
Yep! We also have 5125s (Not application specific version of 5100) rear shocks that will give you the full travel.
Even if I don't go off-road that often?
Got my 5100’s in, does the factory spring perch come off and install onto the 5100’s?
Are the 5100's ok for the front though? I know they're not "lifted" struts so they should be fine for use with the strut spacer on the 5 inch lift right?
Youll be fine as is.
Bilstein offers
Part Number: 24-186636 -For Rear Lifted Height: 3-4"
Yes, it does. Here is a link to Bilsteins install instructions showing the assembly of the front shock -
Yes, they are considered stock replacement shocks and will work fine with the strut spacer in lift kits.
Ok well hope this helps someone.... Was just told by Rough Country that with the 5 inch lift from them, the rear block is indeed 3 inches. And the shock travel lengths are as follows:
Extended: 33.07 inches
Compressed: 19.29 inches
Edited: but apparently that doesn't help because I can't find a dang shock that comes close to those travel dimensions
Edited by Jaycreek7908
ReplaceOk well hope this helps someone.... Was just told by Rough Country that with the 5 inch lift from them, the rear block is indeed 3 inches. And the shock travel lengths are as follows:
Replace
On 3/27/2019 at 7:13 PM, Battle Born Offroad said:
AMAZING NEWS from BILSTEIN!!!
We have 130 sets of the new 6112 for the 14-18 Silverado and Sierra READY TO SHIP!! These will sell out by Saturday and be on backorder again for months! Dont miss out!
Our price is the best around!
GM-Trucks Members get yours here - http://battlebornoffroad.net/bilstein-new-products/bilstein-6112/47273702/i-7531506.aspx
SAVE $100!! Use code: GMTRUCKS
Chas,
Thank you for your time over the phone this afternoon discussing my project and the awesome deal on the 6112's and some 5100's for the rear of my 15 Silverado!!
Looking forward to ditching the Rancho's and enjoying my truck again!!
John in St. Louis
53 minutes ago, quickstang1 said:
Anybody have a shop recommendation in Northwest Houston? I would love to get rid of this crap Rancho suspension on my Z71 and get the 6112’s.
290 NW or 249 NW?
I’m near 290 in Cypress but Tomball would work too.
Tire and Wheel Connection on 1960 & Fallbrook
Cutten Customs close to 249 & Cutten
4 Wheel Parts on 1960
American Wheel and Tire on 290
That's all I know in that area.
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 1,692 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
