9 minutes ago, Battle Born Offroad said:
If you are using the standard 0-1" 5100 for the 1500s and that block, you are limiting your travel by a bit. It will work, just realize the shock is being stressed at full droop pretty hard.
So I should opt for the 5160's then ;)
Yep! We also have 5125s (Not application specific version of 5100) rear shocks that will give you the full travel.
Even if I don't go off-road that often?
Got my 5100’s in, does the factory spring perch come off and install onto the 5100’s?
Are the 5100's ok for the front though? I know they're not "lifted" struts so they should be fine for use with the strut spacer on the 5 inch lift right?
Youll be fine as is.
Bilstein offers
Part Number: 24-186636 -For Rear Lifted Height: 3-4"
Yes, it does. Here is a link to Bilsteins install instructions showing the assembly of the front shock -
Yes, they are considered stock replacement shocks and will work fine with the strut spacer in lift kits.
Ok well hope this helps someone.... Was just told by Rough Country that with the 5 inch lift from them, the rear block is indeed 3 inches. And the shock travel lengths are as follows:
Extended: 33.07 inches
Compressed: 19.29 inches
Edited: but apparently that doesn't help because I can't find a dang shock that comes close to those travel dimensions
Edited by Jaycreek7908
ReplaceOk well hope this helps someone.... Was just told by Rough Country that with the 5 inch lift from them, the rear block is indeed 3 inches. And the shock travel lengths are as follows:
Replace
On 3/27/2019 at 7:13 PM, Battle Born Offroad said:
AMAZING NEWS from BILSTEIN!!!
We have 130 sets of the new 6112 for the 14-18 Silverado and Sierra READY TO SHIP!! These will sell out by Saturday and be on backorder again for months! Dont miss out!
Our price is the best around!
GM-Trucks Members get yours here - http://battlebornoffroad.net/bilstein-new-products/bilstein-6112/47273702/i-7531506.aspx
SAVE $100!! Use code: GMTRUCKS
Chas,
Thank you for your time over the phone this afternoon discussing my project and the awesome deal on the 6112's and some 5100's for the rear of my 15 Silverado!!
Looking forward to ditching the Rancho's and enjoying my truck again!!
John in St. Louis
53 minutes ago, quickstang1 said:
Anybody have a shop recommendation in Northwest Houston? I would love to get rid of this crap Rancho suspension on my Z71 and get the 6112’s.
290 NW or 249 NW?
I’m near 290 in Cypress but Tomball would work too.
Tire and Wheel Connection on 1960 & Fallbrook
Cutten Customs close to 249 & Cutten
4 Wheel Parts on 1960
American Wheel and Tire on 290
That's all I know in that area.
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
