Who's got the Blues?
  • Replies 512
Here’s a couple of my truck. 22ad9d63d16c95e6b383eaa80c84660a.jpgb550c79a0cd6a943e4f41f9281ec1eea.jpg
15 hours ago, CadillacLuke24 said:
Is that grille guard color matched? Looks great!
Yes Luke, the dealer had front and rear bumpers color matched.  I saw the truck online stock, and when I got there it had these installed on it, I started to drive off the lot because I was not wild about them at first.  :jester:
On ‎1‎/‎26‎/‎2019 at 7:35 AM, CadillacLuke24 said:
If you look at the bottom of the photo, you'll see the tailgate is closer to my vantage point on the left than on the right, therefore it is an optical illusion. I assure you my bed is straight and intact :D
As for the vehicle in the background... Guy daily drove it in the summer. I think he may have parked it for the time being, right now there's an 88-92 K5 Blazer in that same spot.
NOOOOOO what happened Leevon??
That is actually a nice 55, hardtop, and all of the trim. The rust looks like me if they did an X-ray, but otherwise a good looking car.
1 minute ago, JimCost2014 said:
That is actually a nice 55, hardtop, and all of the trim. The rust looks like me if they did am X-ray, but otherwise a good looking car.
Typical lower door cancer but it would clean up good...those things are like Gold...will never be worth nothing. Buddy of mine had a 56 (93 Chevy S-10 blue and pearl white) that he sold when he found out he had terminal cancer. The cool part was he sold it to an older (as in can’t drive they were so old) couple in Gulf Breeze, Florida. They literally had the car “pickled” and put it in their house. The only thing they wanted the car for was to watch movies in their home drive-in theater. Don’t know whatever happened to the car, it may still be there.
  • 1 month later...
On ‎3‎/‎9‎/‎2019 at 10:58 PM, CombsL83 said:
Checking in from Ohio. Pic from the day I bought it home. Looks just a little different now.
We have twins from different mothers. Here is mine with a fresh clean up.
Nice looking rig! I can't wait to get mine out of the garage and cleaned up. Think I'm going to try using a polisher for the first time this year.
Here's mine.
No heavy mods. Floor mats, Bed Rug, Mud flaps - no drill, Moroso catch can, rear fender liners, frame tube plugs, rear stake socket/holes plugs, K and P oil filter, Fumoto valve, finger grips to close doors without touching outside, dash cam, radar detector, leveled with rear shackles, BAK revolver X4 bed cover, CR Laurence sliding rear window.
16 hours ago, Squidchevy said:
2018, fresh wheels. Check in from Louisiana!
Very nice. Welcome to the forum.
Shakey
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
