Who's got the Blues?
New to the Forum. Here's my 2017 Deep Ocean Blue Metallic DCSB.
Mods so far:
De-badged
Removed front license plate holder
Tint
Bed liner
Wrapped interior accents
Spectre intake
Added led bed lighting
Much more to come!
Did a color match for chrome swap yesterday with another forum member. Rest of suspension should be here Wednesday. 6/9 Drop going down!
  • Replies 512
Here's our new 2017 High Country with the High Desert package. Just the thing to replace the trusty 2008 Avalanche.
So far loving the Deep Ocean Blue Metallic after owning black trucks for over 20+ years.
Hopefully this color will be less hassle to keep clean and looking sharp than the black especially in the winter.
Great looking truck !
Must be something about that color and people who buy black....I had bought only black cars/trucks from 1990 - 2015.....then I bought the Red Rock Camaro and the Blue truck.
You will love the blue, it doesn't show near as much dust and dirt as the black.
Every truck I buy seems to be blue. My 17 Sierra is no exception.
I have the chrome on my SLT GMC and would much rather the color matched bumpers. looking sharp!
Sent from my SM-G935V using Tapatalk
Not sure yet if I want to pay Photobuckets extortion fee to get my pictures back so I'll just post a new one ..
  • 3 weeks later...
My 2014 LT 4x4 double cab. I've had a year now and haven't changed anything yet. My first truck and love it.
picked it up used with 35000 KM on it. it has 76000KM it now
14034949 10210130967930021 2508668098087321806 N
14045667 10210128959439810 2613639679705198238 N
2015 Deep Ocean Blue Metallic86de459050ef9866944eda380444bd54.jpg68fb9f2d08027db7b41f9bdde98ca1b4.jpg
Do have a Borla exhaust? I like the look of those tips.
I have the BLUES Bad Today. I was washing my truck and the water hose hung on the tire when i jerked on the hose the nozzle slipped out of my hand and hit the fender HARD the brass end dented the fender and dug all the way through the paint. RUINED MY TRUCK. I have the BLUES the BLUEs the BLUes the BLues the Blues the blues
Man I am so sorry, I know that stinks.
I had that problem and hated it too...last year I found these to stop that from happening.
I know it won't help what happened, but maybe it will make things easier from now on.
ADAM'S HOSE SLIDE (2 PACK)
http://adamspolishes.com/shop/exterior/carwashing/adam-s-hose-slide.html
Yep. It's the borla touring cat back system. The non GM branded one. Great deep tone. Not super loud. Love it. Music to my ears. Wish I'd done it sooner!
Sent from my SM-G930V using Tapatalk
Nice looking truck! Got any side view pics of your bull bar? I'm trying to decide on getting one but don't like the ones that stick out too far.
I’ll have a blue in two days stay tuned........
Sweet!
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
