5.3l w/ 3:08 rear
Beer Belly
Looking at a GMC Elevation with a 5.3l, and when I went to the GM Website to "Build & Price", when I added the 5.3l to the build, it made the 3:08 the only rear available.....is this thing gonna be a dog when I tow ??.... :ughdance:
That's not the best gear to tow with.
It drops the tow rating to 6600 pounds.
So that's even less once you start adding in things like the passengers and cargo.
I have the 3.08 and I drove a 3.42 recently. HUGE difference. Get the 3.42, you will be much happier. Even with daily driving, the 3.42 is better.
That bad, eh......Truck MRSP is a tad over $41k......looking at a deal for $33k.....but if it's gonna be an issue, I'll walk.....don't NEED a new truck, just rolling out of one lease and into another.....may buy this one out.
I mean it isn't horrible, but if I had to buy another one I would look for the 3.42 specifically. Just seems to be more smooth. Maybe it is in my head, but I like it better.
Once again, it's all subjective.....I have the 3.08 and it has plenty of power for me, but then I don't haul or tow anything.
Whew !....just back from the dealer....it has the 3:42. Gave it a quick drive down the road....it's doable :driving:
Salesman told me..."Not many people realize this, but run high octane gas and you get better mileage, and a boost to 400 horsepower" :lol:
Guess he doesn't know about E85?
(and that the increase is to 'only' about 375)
And that for the 15 model the 'flexfuel' is optional rather than standard on the 5.3L.
can't find flex fuel around here......I was told on the Interstate, but never in the area.
Running 89 or 91 is almost a must even for the 5.3. They seem to constantly pull timing on 87 and the economy definitely suffers. You won't get 400 HP with 91 but you're almost definitely not getting the power you paid for if you run 87.
don't get the 3.08 - 90% that do have it wish they got the 3.42 ....just read the forum
Got the 3:42 rear.....salesman said "it's part of the Trailer Equipment Package"....I told him "that's good, because that would of squashed the deal". This truck does seem to have a fair bit of giddy up.....not sure the budget manager (Wife) will allow the higher octane :idiot:
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 318 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
