I just bought a Sierra all terrain x and have removed the light bar/ roll bar. I'd like to sell it and price is negotiable. Text 508.509.4036 if interested. Also looking forward to learning from this site. Does anyone know what needs to be done to get cab brake light working now that light bar is removed?
John
I keep waiting for that sport bar to grow on me......I loved the way they looked back in the day
I am looking to buy one of the sports bars. I have about $4-500 to spend. My dealer has one still trying to get them to give it to me for that cheap since GM pays alot less for those from the factory. Let me know
No brake light with my sports bar, but there is a hole. Recon and factory light will not fit. Did the sports bar come with the brake light?
I put the rail under the forward mounts notched it for the rear mount. Just need to add a bead of silicone to seal it up
Hey SF GMC, would you be able to post a picture please of the inside rail at the mount? Does it need to be cut, or is there enough clearance for the bed roll to roll on properly? My hubby and I just purchased a Chevy Silverado with the sport bar, and need to install a tonneau cover. We like the look of this one that you have installed...
I so want one of these for my Sierra but of course my wife thinks it's ugly.
Does GM make one for the Sierra?
Your wife has good taste
X2... pics of the underside if possible. I bought the Revolver with the same idea in mind. I notched the topside, not sure if the underside needs the same.
So i went ahead with this install. The rail on the top side AS WELL AS the side that marries to the inner side of the bed rail also needs to be notched. Not to bad at all, did it with a dremel tool. I will post pics later on.
very nice, well fitting cover when its all said and done.
I just picked up my new Sierra All Terrain X last week with the sport bars....so I am just trying to sort out what the best bet for a bed cover is now. I really like the look of the sport bars and a bed cover is essential for us.....not sure what route I want to go yet. I`m surprised GM hasnt come up with a solution yet.
I just did a BAK Revolver X2 with some minor mods to the rails around the rear sport bar mount. Came out very good.
If you could post any pictures of the notching you did that would be really appreciated!
Yea I would like to see how you did that as well. How are you sealing the sides around where you cut for water leakage
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
