First brake job?
I'm sitting just shy of 35K, and wife and daughter are saying that they keep hearing something when the brakes are applied.
  • Replies 87
Just did mine at 61000. Rotors and pads all around. Got replacement coated rotors. Figured if they lasted that long it's worth the investment
Brakes are not covered under warranty. There is also no "expected" brake life due to the different driving conditions and habits of each driver.
I did my fronts around 80k - got a quick question though. My brake pedal (even before I changed them) seems to not have the same pressure built up when I hit the brakes like it used to when new. Is this a brake line issue?
The pedal doesn't go straight to the ground or anything, but it definitely a lot different feeling then when new. And i notice if i pump the brake once or twice it seems to stiffen up the pedal a lot more.
Bleed the brakes.
I have 67k on my truck. Drive a lot of city driving, have towed and since 53k I have +1 size E load KO2's. Brakes on my last oil change few weeks ago looked great. 50% left and the brake fluid in the reservoir is exactly halfway between the high and low mark.... so 50%. But I have a rear rotor that is warped, I can feel it under medium pressure with some speed like coming off the hwy.
I have the same vibration in my truck. It's been present since bought mine at 42k miles. What pads and rotors for a truck that is mostly a daily driver and will pull a 4x8 utility trailer once in a while would you guys recommend? I want the least dust as possible so ceramic pads will do.
Honestly, I found an AC Delco dealer nearby and bought the replacement coated rotors. Within a few dollars of others and I figured if they lasted 62k in upstate New York winters they were pretty good.
I'd recommend doing a full brake fluid flush and and full bleed of the system, especially if you're driving a 2014 or 2015; ie a vehicle more than 2 yrs old.
2015 and that's what ill be doing this weekend. Thanks!
I power flushed mine to NAPA DOT 4 brake fluid when it was almost new. Has a higher boiling point, but won't last as long as DOT 3. I ran the same stuff in my two BMW's for years after getting tired of $10 per pint at BMW. When it comes to brake fluid, the color tells you everything. When it starts to darken up I flush it out. I like to keep clear fluid in the thing. So for me in FL with high humidity, 18-24 months is my track record with multiple vehicles and DOT 4.
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
