Some people say it's just by miles, so 75 miles per 1% of the oil life. But, so far mine hasn't come up to be exact, so maybe it goes off both miles and hours. I keep my Trip B set on the oil life so I just go by that and don't really focus on the oil life.
I've tracked mine since day one, it varies between 6000 and 7500 miles depending on how hard the truck is used. Since these trucks monitor many parameter (e.g., oil pressure, oil temp, rpm, load, engine temp, etc.), it must take those into account in some aspects to determine roughly how hard the oil is abused.
Sent from my SM-T350 using Tapatalk
It uses driving characteristics to decide how many miles compared to the percentage. If you drive more city miles, it will be less. If you do more highway miles it will be more.
On average it is around 75 miles per 1%.
NOTE: I had my oil changed this week and told the #2 advisor I wanted full synthetic. She said the dealership used a syn blend but I said for the $25 up charge I wanted to run full syn. She said ok then a few minutes later came into the waiting room and asked how many miles I wanted the OLM set to to indicate my change interval. Um, 7500. Ok. Done.
That is interesting, I haven't had them ask me that yet on my new one or any of my old ones. I just dropped it off yesterday morning for one of my free ones and a whole list of warranty things to get looked at fixed. I will ask them when I pick it up though (no eta yet on when hehe).
The GM Oil Life Monitor(OLM) system is not a mileage counter. It is actually a computer based software algorithm that determines when to change oil based on engine operating conditions. There is no actual oil condition sensor. Rather, the computer continuously monitors engine-operating conditions to determine when to change oil. Over the years, millions of test miles have been accumulated to calibrate the system for a variety of vehicles. The system was first introduced in 1988 and is now on more than 10 million GM vehicles. Using this system vehicles might go as few as 4000 miles under harsh city driving conditions or as long as 12000 miles in optimal conditions before the monitor would indicate that it is time for an oil change.
This system caused some concern among service providers when it was first introduced. They were concerned about whether or not the engine would be protected operating at these new longer intervals. They were also concerned that these longer oil change intervals would drain some of the volume from their service departments. Because of this conflict of interest, it was hard for the customer to get a clear read on when they should change their oil. It turned out that the system worked pretty well for most of the customers. We did not have any problems that we attributed directly to the OLM system. During this period we generally recommended that customers change their oil on their GM vehicle about every 6000 miles, or according to the OLM, whichever they prefer.
^ Thanks! Reading what Boardmember posted in post #5 makes me wonder if the OLM is adjustable?
Edited by OldBlue61
fyi...................
Since 2010 all GM vehicles have been equipped with the oil life monitor (OLM) system
The monitor calculates the percent of oil life remaining, based on 3 pathways
The OLM starts its calculation for all pathways after the first 50 miles to account for marshalling and time before sale. Subsequently, calculations begin immediately after each reset.
Recommendation/Instructions
Oil Life Monitor Calculation Pathways:
1. Engine revolutions- Oil life starts with a fixed number of revolutions and will decrease with each revolution. Cold / hot coolant temp readings have multipliers that reduce engine revolutions pathway quicker depending on how far from the normal oil temperature the vehicle is operating.
Note: If engine coolant temp gets above 260F, engine overheat condition, the oil life will go to 0%.
2. Mileage from last reset – Starting with MY 2013, the OLM is capped at 7500 miles for all GM powertrains except the Volt. In perfect conditions a vehicle would reach 7500 miles from the last reset and the oil life left would be 0%.
3. Time- This pathway is a liner function, a fixed decrease in oil life for a given time after the oil life is reset. The oil life will drop to 0% after 1 year regardless of the amount of engine revolutions or how many miles since the reset.
Note: The Volt uses a 2 year timer instead of 1 year. It also uses the engine revolution counter. It does not use the mileage pathway to count down.
If you can't dazzle them with brilliance, baffle them with bullshit.” ― W.C. Fields.
OLM is not adjustable unless Gm issues a re-flash/update to the PCM. That is what GM did on the earlier Equinoxes with 4cyl. My in-laws bought a '12 IIRC and the OLM came out around 10k for an interval. After a year or 18 months the dealer re-flashed it and now it's on the 7,500 interval.
I always told them to max it out as far as I can and still mantain my warranty, they usually double it. Otherwise why bother. The miles I drove I was there way too often. Wanted to shorten trips to the dealer.
There appears to be some flexibility to affect at least the baseline from which elcamino'spost indicates takes place. That I was asked and responded 7500 doesn't appear to conflict. I may have asked for the max they would have allowed.
Karnut's post indicates similarly.
My first oil change was at 2200 miles and it appeared to have been calibrated to give me 6000 miles to 0%. That was dealership syn blend and I'm not driving in extreme duty conditions, except it is summer...
I have 100% personal confidence that 5w-20 Mobil1 full synthetic in my engine with my driving requirements - for 7500 miles - is absolutely fine.
Oil analysis is a good way to accurately determine how long you can run you oil. Also your oil may still be good but it is limited by the filter
Ryan
As stated above, the dealer cannot alter the limits of the Oil Life Monitor, that option does not exist for dealers.
    • IMNTBHO;  the worst thing for the 6L80 is to be lugged down to low engine rpm while in high gear......AKA, to save fuel.   I rarely use D on my '16 with the 6L80 and use M mode to keep engine RPM above 1500 at the speed I'm driving, which is also benefiticial for the tranny because line pressure is kept up because the pump is actually turning a decent speed, and it's not always hunting to drop to the next gear to lower the engine RPM's.   Never above 30mph.............M3, maybe M4 if just driving thru a small NoDak town Never above 40mph............M4 Never above 50-55mph.............M5   This is way better for the tranny and the engine.........especially if AFM is still active.   262K miles on my OEM 6L80 as I type this.
    • If they had nuclear material for "11 nukes" we'd have seized it.    Our military has been rendered either too weak/dumb to seize it, or they don't have it. Your pick,K-nut. Because right now we're fighting over who gets to toll oil tankers in the strait.    I hope you're man enough to admit you've been taken for a ride when it's finished.
    • I hope you’re man enough to admit that you were wrong when it’s finished.
    • And you're obviously full of it too.  Apparently anything he does is perfect to you.  Don't you think this whole ordeal would have been better if he had maybe thought it all through first before bombing Iran at the request of his bffs in Israel, Saudi Arabia, and Qatar?  They are the ones that had the biggest issue with Iran.  Thus they have been pouring the platitudes and giving gifts/bribes to him.  Had he thought about the consequences of what would happen to the Strait before starting anything, we wouldn't have this issue.  Now he is stuck with no way out of this mess.  But you have your head stuck way deep in his rabbit hole to see anything else.  So no, I don't have TDS.  I see what he is.  The derangement is yours from no oxygen in the rabbit hole.
    • Bringing of the fact that every President has said the same thing. They can’t have nukes. I guess you missed that before epic fury they said they had enough product for 11 nukes and weren’t giving it up. That not political or polarizing. The opposition of that is and giving aid to the enemy. The mandate is decades old through many administrations. The difference is TDS.
