23 hours ago, Yordany said:
I just checked these out on Amazon, they claim that it does NOT fit my truck.  HAHA!!  Ordering 2 pair later today.
 they do fit perfect
27 minutes ago, Yordany said:
 they do fit perfect
I figured as much, but just found it a little humorous that "they" think that these don't fit.
1 hour ago, BigBlueLB756 said:
I agree about the mess when changing oil in these trucks. 0W-30 comes out like water and goes every where. What I did was buy one of the Fumoto Valves and it has a nipple on it. When it comes time to change oil, I put a length of tygon tubing on it and drop the tubing into the drain pan. No more mess!!
After fighting with hot oil spray each time changing the oil on my 08 Silverado I added the Fumoto at the first oil change on my 2015 sierra.
I really like the idea but I don't trust brass in our heavy salt sprayed roads. Very neat - would totally jump on this if I lived in warmer climates.
Having spent 10 years in the Navy I have no issues with brass & salt. Many over the road trucks running them with no issues either.
 What’s everyone doing about the oil filter change? On the V6 its above the plastic shield and I catch heck trying to remove the filter without making a mess. Filter relocation?
Last timeni checked it was about 5 bucks more to go to the dealer, not worth the aggrivation to do it home cor that
What are you talking about?
48 minutes ago, Waaazooo said:
Where can you get an oil change for $5?
i believe he meant $5 more at the dealership vs buying your own stuff
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,303 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
