6 minutes ago, Beer Belly said:
It that an Air Bag I see ?.....is the new trim compatible with the Air Bag (if that is what I'm seeing ?)
Yes and yes, it's a Genuine GM accessory. The nut-plates are already there from the factory and it is held in the same way as the passenger side handle. The stock non-handle trim has a retainer lanyard to keep the trim from blowing into your face, this one doesn't as it is attached by the same two bolts as the passenger side.
Edited by SS502
On 10/2/2016 at 9:52 AM, pgamboa said:
Phillips LED Reverse and Cargo Lamps
Driver' Assist Handle
Frame Tube Plugs
Footwell LED Lighting
Cargo Net
Regarding the footwell lights, did you wire them to turn on when you opened or closed the doors?
I’m not OP, but I wired my footwell lighting to match the dome lights. He has a post on where to jump off the wire. And then ground some where. Works great!
BCM taps:
GRY-8 = Driver's mirror puddle light
GRY-14 = Driver's Door OPEN Switch
GRY-25 = Passenger Door OPEN Switch
5 hours ago, Ravenkeeper said:
BCM taps:
Thank you!
Witch led  lights are you using for the footwell
I bought a long roll of LED lights from amazon pretty cheap. I cut them into the length I need, solder the leads and then installed them. It’s been great. Just need to cover the solder points.
On 8/9/2018 at 9:34 PM, Jmiller11331 said:
fcc0c5b319fbfcfe9e3081480b6234fa.jpg added a OEM high country leather wrapped cluster visor to my truck. Alittle over $50 but close to it. I enjoy it and it lets you add whatever color leather you want.
Where did you purchase that visor?
I can add a cheap mod to this thread.
I saw some .45acp shell casing valve stem caps for sale where I got my windows tinted. I thought the idea was cool, but the .45s looked a bit much. Tried some .40S&W casings when I got home. They fit perfect! These are nickel plated Hornady Extreme Duty casings, so I’m not expecting any significant oxidation or discoloration like brass.
So far I have  -
Replaced the upper half of the mirror with Chrome pieces.
Installed the Driver Side Assist A Pillar
Installed the Round Chassis plugs modified to allow some air to circulate through the tubes.
Oilless high flow air filter.
Front and  rear Weather Tech Mud Flaps
On 12/9/2016 at 9:00 PM, iamdanieltuck said:
An oem wiring harness to access rap, battery power, crank accessory power and ground. $45 is a cheap way to insure we don't short something tapping it or catch on fire.
$45 plus shipping
you still around? i have a few questions. i pm'd you
4 hours ago, chuckworkb said:
Is there a part number for that harness?
no it was a harness a member was making up himself.
Its very straightforward to tap power out of the driver side fuse box.
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
