K2 Diablo Tune
sdog4127
if you run the 87 oct tune, is it safe to run 89 oct?...
  • Replies 114
Top Posters In This Topic
Yes, thats what I am currently doing.
Thanks AZ.. i always wondered that... ..
Here is a post I made in another Diablo thread regarding TM:
The first time I tuned with the inTune i2 I turned upshift TM (torque management) off and went with the firm shift setting. While the shifts were firmer, they were randomly firmer. Every so often the 1-2 shift would be really firm and then sometimes soft. After doing more research on upshift TM I decided to turn it back on (stock setting). I think the shifting is more consistent now. Partial throttle shifts are a little more firm then stock and WOT shifts are firm but not harsh. This is what Mike on the DIablosport forum said about upshift TM:
"we often recommend leaving the upshift abuse mode TM enabled as it can lead to sloppy shift feel when disabled, as you may have discovered. TM on the engine side is already disabled in the tunes."
"this is TM specific to when the trans upshifts in 'abuse mode' meaning heavy throttle/WOT, leaving it on allows the pcm/tcm to make the shift smoother, turning it off removes any timing/throttle adjustments to smooth out the tune."
It sounds like there are two TM settings. One on the engine side and one on the transmission side. The engine TM is turned off in the canned ECM settings (87 or 91 tune). The transmission TM (upshift TM setting) is the only user selectable TM option and is under the advanced TCM settings. I plan to leave it on as I think it feels better and really don't see any reason to turn it off as I don't think it affects throttle response (power to the ground). Appears it simply pulls timing between shifts and turning it off can potentially cause slopping shifting.
I originally ran with TM off (disabled) and also noticed strange shift habits, normally under light load or a range of 20~40mph while light driving around town.
So I changed my original parameters from this :
12/21/2016
The settings I have used on my 2016 Silverado 5.3L 6 speed Auto w/ 3.42 gears are,
87 octane Performance tune.
Firm Shift Transmission tune - ON
DOD (AFM )- OFF
TORQUE Management - (OFF)
Throttle boost - (range is 0-25% ) I have it set at 3%, *Curious to know if anyone else has messed with this setting?
Adjusted + 50rpm in gear and + 50rpm in neutral and park.
Mods- Currently Running K&N Black Hawk Series CAI, w/ a full Banks Performance Stainless Steel cat back.
Now: as of 4/11/2017
DOD (AFM )- OFF
TORQUE Management - *(ON)
Throttle boost - (range is 0-25% ) Now I have it set at *10%,
Adjusted + 50 rpm in gear and + 50 rpm in neutral and park.
I did not notice any power lost on up shifts, and with the slight bump in the throttle boost, the truck kinda "feels" quicker?
For those of you that have played around with the throttle boost parameter, have you noticed increased engine speed at idle? Maybe I'm not understanding exactly what the parameter does. With the stock tune my truck idles around 550 RPM when in park/neutral and 500 RPM when in gear. With the 87 Octane tune and throttle boost set to 10% the idle speeds change to around 900-1000 in park/neutral and in gear. Is this normal behavior when playing with throttle boost parameters or am I missing something?
I used to run 20% throttle boost but right now I'm running torque management off so I turned the boost off (I'm basically just trying to feel what the individual settings are doing). I'm also trying to gain some mpg's back.
But to answer your question, when the throttle boost was on I did not notice a change in idle. Is it possible the truck was cold? I did however noticed it shifted higher in the RPM range with throttle boost on. I think what is happening is the throttle position is not being read properly so the tranny acts a little different. What I noticed most was the ease of driving in the highway - very little pedal input needed with throttle boost on for long highway trips. I loved having throttle boost at 20% but like I said, your mpg takes a hit.
Sent from my Nexus 6 using Tapatalk
When I noticed the increased idle speed I'm sure the truck was warm, or it should have been. I took about a ten mile drive after I changed the tune parameters and it was about 75 degrees last night. I stopped by my buddy's house because he was outside and I was talking to him and that's when I noticed the difference in the idle speed. Also the temp gauge was reading around 210 degrees while doing so. I re-installed the stock tune when I got home and things were normal again. I may try to re-install the 87 Octane tune and adjust the parameters again and see what happens. I was thinking the way the parameter worked was that as soon as the throttle was pressed it would immediately advance X% forward, i.e. would jump from 0% to 10% throttle as soon as pedal was mashed. Mine acted like the throttle position was moved from 0 to 10% and that is the minimum that it would go down to. But then again, maybe I'm not understanding what the parameter actually changes.
Right, I think 0% throttle is still 0% if that makes sense. That's the way it felt anyway... I would give it another go and report back if you don't mind.
Okay, so after I re-installed the factory tune I installed the 87 Octane tune with the 10% throttle boost and everything seems to be normal now. It must have been a fluke when I changed it last time.
I like it. I can tell there is a little more low end response when I need it. This plus the transmission holding lower gears longer helps a lot with acceleration.
So how high is your idle now at park and in gear with your adjustment
I get my tuner later today so trying to figure out the best settings. Im not a hot rodder. Just would like it to have a better idle and get better mpg's and I'll be happy. If anyone can recomend the setting to get that I'd appreciate it! Thanks.
Ive got 87, 91 and 93 octane down here and would like to use the 87 or 91 if I have too
I have my idle RPM in both park and gear set to +50 RPM. I like this setting as it seems to have smoothed out the idle (especially when at a stop in gear with the AC on). I have the throttle boost set to +15% and this helped a lot with throttle response. Throttle boost did not affect my idle any. My fuel economy hasn't gone down any either. In fact my overall MPG is maybe even up a little. I drive mostly highway though.
Here is what I have mine set to:
- 87 octane flex tune
- Trans tune firm shift
- DOD off (V4 mode)
- Throttle boost +15%
- Idle park/neutral RPM +50
- Speed limit off
I had upshift torque management turned off and throttle boost at zero originally. I decided to turn upshift TM back on as it seemed to do nothing for throttle response and made for occasionally sloppy shifts. Throttle boost made the most difference. Later found out from the DiabloSport forum that the engine tunes disable engine torque management. It's built into either the 87 or 91 tune. The user selectable TM setting is the upshift TM setting and this is different the the engine torque management. This is what they said on the forum regarding upshift TM:
I haven't messed with the idle at all yet, but as far as my other settings, I run the 87 octane tune with DOD/AFM off, 3% throttle boost, speedometer corrected, speed limiter off and trans firm shift on.
I flashed it back to stock to take it to the dealer this morning for my last free oil change of the 2 yr 24k mile deal and didn't really realize how much of a pig it drove like before.
As soon as i got out of the dealer I pulled around the parking lot, installed the tune again and was completely reminded of the changes that came when I first installed the tune.
My highway MPG has definitely gone up a couple MPG's and the city mileage is better as well. I have so many stop lights on my commute and such a heavy foot, that too much throttle boost just kills my MPG because I can't keep my foot out of it lol.
I'm already talking with Lew and will be doing a data log for him next week and getting a custom tune, I'll keep yall posted on those changes as well if anyone is interested.
Please excuse my last post. Posting off a phone doesnt work sometimes. Ive noticed that people are deactivating the AFM. Any particular reason for doing this? Have you seen a drop in milage due to this? thanks.
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
