Realistic mpg's
My air pressure was set at 34 all around the other day at the dealer. This time of year in New England I'll let the truck sit a day or 2 in my garage and they'll be down to 31-ish upon start up. Normal fluctuation?
I'm around 15.9 with 80% town driving. I've tried driving just in 2WD as opposed to Auto as someone suggested that would help. Tried that for a few tanks, but no real movement of the MPG meter.
  • Replies 73
Sounds normal. We get customers in all the time right around this time and their tires are down 5-10 pounds on average.
Ya pretty normal, but for me it's weird because it seems to always be just 1 tire that falls like that. The others won't budge or not enough to notice.
14/21, average 16 but I've only got 800 miles on the truck. 5.3 8 speed.
Once I drive they'll warm up but I just find it interesting I'll lose 4lbs or so of air consistently while it sits. I don't know .... [emoji57]
now that i have bfg k02 on my 2014 5.3 with 3.08gears, this truck is not any better on fuel than my 2006 was. a 10 degree temperature drop will deop your pressures 4 lbs. i have a fleet of trucks that run from canada to florida, it is the hardest thing to do is find a happy medium for tire pressures going from the cold to the hot all the time.
'17 crew 6.2 3.42
stock tire size
warm weather was 17.5ish town 22.3 highway
winter 15.3 i
around town 20 highway
5800mi on it now
The lifetime average on my 14, 5.3 4x4 is 16 mpg. I do drive 45 miles one way to work but there are lights and I live in the hill country so the hills mess with my mpgs.
According to the computer in the truck, which is a bit optimistic I believe, I am averaging 20.4 all time. Last 400 miles is 19.0 with a best of 21.9.
Regular Cab 4x4, 5.3, 3.42 gears. No mods. I was hoping for better, but it looks like I'm doing better than most.
2016 Silverado RC 5.3 3.42, 25 miles one way commute to work primarily a 55 mph zone with a couple stops along the way just did 18.6 mpg. Truck is stock with no mods.
35 is actually low for a full size truck. I had factory Goodyear SRAs on my '14 5.3 and always kept it above 40, usually was between 40 and 45.
For the factory SR-A the recommended is 32psi.
Says who? Just because you have yours cranked up doesn't mean that is right. For a p-rated tire running around near max psi is too high. Just going by look is wrong and is not a better way to figure out where to run versus tire engineer recommendations.
Tyler
False
Tyler
I have a 2016 regular cab short bed 5.3 6 speed with 3:08 gears, 305/40r22 tires (35 psi front and 32 psi rear cold with no load) and about 2500 miles. 95% + driving is short trips around town and last I checked average was around 12mpg. Can't remember what it's "supposed" to get since mileage wasn't a big concern due to the amount of driving I do (3-400 miles per month)
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,555 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
