Message added by Zane,
Hey all — this question comes up regularly, so we've put together a full reference covering lug nut torque, bolt patterns, stud sizes, and socket sizes for every Silverado, Sierra, Tahoe, Yukon, Suburban, Escalade, Colorado, and Canyon from 1999 through 2026.
👉 GM Truck Lug Nut Torque Specs: 1500, HD, SUVs (1999–2026)
Yep, torque.
Late 90's lots o us fbody guys had warped rotors. We determined cause was wheel torque. Since then I've always torqued wheels by hand and never had an issue.
Maybe I'd think differently if I were a full time mechanic. But as a home mechanic - I do everything by the torque # listed in the manual.
For the curious, the 140 ft-lb spec is in the 'Capacities and Specifications' section in the back of the owners manual.
Just wondering out loud here, but I wonder if some of the Chevy shake problems could be from the lugs since some have mentioned that they can cause vibrations?
More so if the wheels are lug centric. If you don't torque the lugs in the proper order the wheel can be off center which can cause vibrations.
I always torque, sometimes in stages if it's on aftermarket wheels. (I.e. criss cross pattern, hand tight, 50lbs, 100lbs then final torque value.
Sent from my SM-G930V using Tapatalk
So it seems getting the lugs too tight is more of an issue than people not tightening enough. If they have been over tightened thus stretching the studs and possibly warping rotors, is the damage already done? Is there any reason after the fact to go back, loosen and re torque?
You have to watch those dummies at the dealerships that just use an impact wrench, they will warp the shite out of your rotors.
I nearly lost a wheel once when my brother used an impact on my lugs. Two days later, I heard a horrible banging sound coming from the back of the truck which turned out to be a wheel held on with one loose lug nut and two of the studs were broken off. Luckily, I was in town and not on the highway.
I do that, I have them leave the centers off until I get home, then I loosen and torque everything evenly. Again, depends on the shop...some do it right.
Lug Nut torques specs-Is it really that important?
Yes
While we're on the subject of fastening wheels, do NOT use lube on the threads. The spec applies to dry threads. Lube (including never-sieze) will result in over torquing.
Edited by redwngr
Torque wrench and socket underneath my back seat... I check them every month since I put aftermarket wheels. Not one is loose.
I just rotated my tires today...every time I torque my wheels to the ridiculous 140 ft lbs i say a few Hail Marys hoping nothing strips. Seems like a ridiculously high amount of torque
This topic is now closed to further replies.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 473 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
