Techron is a fuel injection cleaner and my point is it won't help prevent carbon build up on your intake valves. I am not aware of any product that can prevent carbon build up on a DI engine.
Yes I read that as well on their website and its all in how its interpreted for one thing and I believe the GM spec itself does not call for enough volume to bring the oil level up to the bottom of the factory covers fill/level port which also is puzzling. Banks are also bouncing between two different truck makes in the instructions since both the Ram and the GM use AAM axles with those instructions.
The problem with not seeing the oil in the window is that one has no idea where the actual level is. Certainly anyone else on here reading this and having worked with the banks covers should chime in as they may have more information to provide. I am just simply concerned because I don't want to see someone underfill the diff as its not just the diff that is critical to lubrication, its the wheel end bearings. The dealership I bought my truck from had two HD pickups a while back have their rear wheel bearings fail because of being too severely underfilled at the factory and no one had checked and topped them off at the dealer but luckily warranty paid for a whole new complete axle housing as it mangled the axle housing spindles when the bearings failed and sent metal throughout the whole diff.
No, not yet. Hoping I'll have something a little more definitive in the next day or 2. They seemed to be very confident they can order it. I do have some understanding of the whole allocations and restraints stuff so we'll see.
I think this is what I'm looking for.
3000 ORDER ACCEPTED BY PRODUCTION CONTROL
Then you haven't read your book. It also says check every 400 miles.
If you need to add multiple quarts in that distance then reading the stick isn't the issue. Put the two together and it will make sense. Read it all.
