This is the battery tray, secondary auxiliary relay, and the optional 3 fuse box and cover for older model years if you want to replace the single fuse box on the aux battery harness:
P1140091.thumb.JPG.637d4919ac6459658598cd0667a8e9a3.JPGP1140085.thumb.JPG.1f50169f898eb2767e3c8e96ae9f8f48.JPGP1140088.thumb.JPG.20e911343e0cdbd0563fe85f11d37058.JPG
This is the factory harness between the primary battery and the X50A underhood fuse box:P1010864.thumb.JPG.0343bd904b59b5bf7cf8d6937eedfbe6.JPG
This is the aux battery harness that replaces it and adds the relay for switching the battery isolator, cable running from the primary battery distribution block to the isolator, cable running from the isolator to the aux battery (including the battery terminal with a 125A fuse), the connector for controlling the isolator, and the connector to control the aux battery switching:P1010844.thumb.JPG.de928d415d9aaab933b40255d4a8c19a.JPG
Here you can see the blank screw on the primary battery distribution block - the cable running to the isolator hooks up there.
This is the connector on the aux battery harness where ground, (+), and the control signal (run/ignition) need to get in:
This is the service terminals that connects to that connector. I ran black, violet/brown, red/white wires in the standard flex installation hose along the firewall (connector is on passenger side, my wiring goes back to the driver side)
Here is the battery isolator secured to the firewall. I pulled out the black wire right there to connect to the ground post.
This is the connector where you need to connect the red/white wire from the harness (the terminated lead wire is white)
P1010959.thumb.JPG.152cc71f701d61b424b3f75314a99a8a.JPGP1010960.thumb.JPG.3401ecb312b15e8ad0fdb0acd946204c.JPGP1010950.thumb.JPG.c3982bd7979a619db5ae9085a4590be2.JPGP1010951.thumb.JPG.ebedd8578c7a85278c711eb8e2969285.JPG
This shows where things come together with the red/white wire going to the service connector:
P1010968.thumb.JPG.31eb6682dddd08be84c8ceffa1a07872.JPGP1010969.thumb.JPG.c8398ac358d72afacbe8c849a5233ccb.JPG
Violet/brown can just be tapped into on the engine/body connector:
All done (except for the aux battery which is on order, so I left the cable going to it disconnected from the isolator just to avoid having to heavily isolate it).
P1010979.thumb.JPG.4dee600490e484b0074d282c32205580.JPGP1010976.thumb.JPG.cc70eedad6b064425e1d46d6921185fb.JPG
Edited by Vuk
  • Like 4
What am I missing? Two identical batteries in parallel just doubles the amp capacity and capacitance. Literally acts like a battery with twice the CCA and reserve minutes. So...why isolate and use/charge independently? The alternator doesn't care and the ECU hasn't any idea how big the battery is. So I'm guessing there are other reasons for this???? Educate me...
My first diesel, 91 dodge had one battery. We definitely had it the longest, it just worked out that way. Never had an issue. Two batteries in diesels there after. Didn’t see the point.
Normally it is marketed for the plow guys. They can hook up to the 2nd battery all there accessories and with truck off if truck dies you can start truck. This is why the battery doesn't connect in cranking. It would only hurt the first battery if 2nd was dead.
Ah!!! Thanks.
In fact, ECUs can estimate the battery capacity by keeping track of the discharge rate through the current sensor, which these trucks have. I wanted an auxiliary battery for a 2-3kW inverter, but thought that it would also provide me with a secure start in case my primary battery dies (just of old age because the BCM seems to reserve the right to shut things off if the battery discharges below a certain point).
The fact that the factory fuse between the batteries is 125A explains that the aux battery is not meant for cranking.
Edited by Vuk
Great write-up Vuk.  I only wish my 2018 could use it so I could make my setup OEM like that.  Unfortunately, looks like they've made some changes with the '18.
All the wiring info is from the 2018 builder's manual. The part numbers I got printed out from a dealer, so not sure if the battery tray or the harness would be the same.
Edited by Vuk
Haven't had time to pull the cover off the primary distribution block on top of main battery, but it looks to be different than yours.  I also read in another post, I think, that the '18 changed.  Looks like I have a small ECM on top of my battery, and the cover/charging/jump post looks different.  I'll have to get that cover off to verify.
Could be that it has changed at some point during 2018; I am not knowledgeable enough to say anything about that.
This has my interest. How can a current sensor tell the difference between a 30 amp draw on a 600 CCA system v a 1200 CCA system? Unless I don't understand what is meant by 'rate'.
It guesses. But really it has no clue if there is one or a million batteries. My understanding is it sees voltage and current draw. Nothing fancy just a sensor. And thinks it is low it shuts off circuits. Much like regulating the voltage output on the alternator based on the voltage.
There was a post long ago when we talked of getting the sensor on both batteries so it can learn. But no one tried it. I don't have it and never a issue because vehicle has no clue.
But now you have me thinking. If I grabbed the signal wires and just feed my relay it would work like yours then swap signal wire and the connect on key on. [emoji2962]
I picked up a 48PG battery today and installed my three-fuse modification. The original negative auxiliary battery cable 84354708 seems like it would never be delivered, so I picked up 22846471 (at about the same price) and removed the sensor. This one gives an additional ground lead of decent gauge that can be used for accessories, which is even better.
I've replaced the 175A fuses with 250A as a preparation for a 3000W inverter running off of the aux battery. I will post pics once the battery lays down in the next couple of days.
Edited by Vuk
My setup is complete now with nice factory-looking points to hook up an inverter. Should I ever need to jump start the primary battery, I can always run jump cables from aux battery to the primary.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
