First of all, how do you search the forums? I can't see an option to do so.
Now, on to my topic of concern.
My truck (2014 GMC Sierra SLT) was built in February of 2014, purchased by an owner who had it for a couple months and decided he wanted a diesel truck instead. Basically he took his truck and reordered the same truck but a 3/4 ton with diesel and traded this one in. I purchased it in July of 2014 with only 5,000 miles on it. Got a pretty good deal too. I love everything about this truck but the payment...
And the frame now...
When I checked out the truck before purchasing I even got underneath and checked out the undercarriage. Still looked clean and new. When I was signing the papers they offered me an appearance warranty which would cover paint issues, damage to the interior, rust, etc. They offered me a good deal on that so I bit on that as well. Part of that package included an undercoating and protective spray coating of the frame and suspension components. Said it would significantly delay the onset of your typical surface rust on the frame.
Check out these pics:
(this should be the maximum amount of rust visible after only three years and that on an untreated frame...
Am I wrong to expect less rust, especially after a protectant has been sprayed over the metal? How good can 'high-strength steel' be if it rusts this much after only three years?
This vehicle has never been submerged in water much less salt water, and during my ownership hasn't even been driven that much on salty streets in the winter.
I working with the company that warranties the treatment and with the dealer but I'm fearful that their 'fix' will be just just scrape off the loose protectant and rust scale and just reapply the coating over the leftover rust.
Anyone else having this issue or is it just my truck?
They all rust here and there. Mine did. Yours has more than mine, but it's just surface rust. It's not affecting the integrity of the structure. Even if you did nothing about it, it would take a very long time to compromise structure. That being said, what I did was go over the rust with a wire brush and got all the loose flakes off. I then painted it with Permatex rust converter. Once that dried for about 24 hours, I applied Daubert Nox Rust, which is the factory wax coating. It looks brand new.
One question in your situation is what product did they spray on your frame. Some of the products degrade the factory wax protective coating and actually leave your frame exposed.
This was my first thought as well.. wondering if whatever undercoating they applied completely counteracted the factory wax coating?
People are still driving trucks built in the 1990s (me) more holes than swiss cheese and the frame hasn't cracked otherwise broken yet.
I appears you paid for something they didn't do. There should be some trace of the protectant somewhere. I'm not seeing it.
What he said ^^^
Not sure about the US, but in parts of Canada they use a thick tar like substance to undercoat with when you buy that option at the dealer. None of that is present in your pics. It looks like it's just the original frame wax.
Edited by 3beejay3
That's just down right sad! Not sure the build date on mine, gotta look. But I noticed a few on like weld areas of the frame, and it's a 2015.
I {am} working with the company that warranties the treatment and with the dealer but I'm fearful that their 'fix' will be just just scrape off the loose protectant and rust scale and just reapply the coating over the leftover rust.
It sounds like you are on top of the situation and need to see the preparation done prior to them reapplying any coating. Keep pictures like you have here of the process. I have owned many trucks and lived in areas with pretty harsh winters and have not seen this type of rust pattern on the oldest of my trucks. If I was in your position, I would take these pictures and a copy of the "appearance warranty" for preliminary legal advice. Your truck is safe and you will probably not own it long enough for rust to be a problem. However, as it is, your chances of a good price at sale time are pretty slim!
I know gm uses that crappy wax coating, but at least give us an option when ordering a new truck to have the frame powder coated for an extra grand or something. I'd pay it.
It looks like they actually stripped the wax coating off the frame that came from the factory. I don't know if all trucks came with it, but it doesn't look like they did anything.
Some 2013 and 2014 frames were noted for the wax coating peeling right off, leaving the bare steel surface very vulnerable.
Personally, I'd prefer it to be galvanized or something. I'd at least like the option here in the rust belt and would pay a reasonable amount for it.
Edited by 3beejay3
Looks untreated and normal for that, just my opinion. I get mine sprayed inside the body and the underside from krown rustproofing. No sure what is available in the states but it takes care of it up here.
My 2014 is at the dealer getting this repaired right now. There is a repair bulletin on this although I had to call 8 different dealers to get one to actually make the repair. TSB# 14002A or #pI0564H should be the correct bulletin to reference
    tblt44
    tblt44
  • Who's Online   6 Members, 0 Anonymous, 676 Guests (See full list)
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
