Hi all,
I am looking to start a slow conversion to turn my truck into something like a prerunner and I'm looking for suggestions and advice.
Current set-up:
2015 LTZ Crew cab 4X4 w/6.2L and 8spd tranny
-Rancho Quicklift Leveling Struts
-275/70/r18 General Grabber AT2(on stock alloys)
Goal:
-Make my truck look something similar to the 2nd picture
Information needed:
-What is the best order to do the mods in considering some require others already be in place?
-What parts will I need aside from bumpers, fiberglass fenders/custom fender wells?
-What parts will 35's or 37's rub in the front? In the rear?(assuming I already have 3inch or 5.5 inch fiberglass fenders already installed)
-What issues will I run into with each modification?
-When after I get to the desired appearance, what suspension is highly recommended for daily deliverable yet efficient off-road(i.e. Fox 2.0? 2.5? Icon stage? King ? Etc.)
Thanks!
That just looks like bumper fender extensions, wheels and tires, shocks/lift.
Are you looking for actual high speed off roading? Or just the appearance
Yes, that is indeed what it looks like but since it's only a minor lift/level I need to know what mod make the 35's or 37's possible besides the fenders.
I want the appearance first, then I will eventually invest in the struts/shocks to make it functional at high speed off-road.
I suggest contacting rogue racing and asking for the specs on that truck. They would probably tell you everything. offset and backspacing and all that confuse me too much to help you out there but prerunners generally have a higher lift in the front than the rear.
That truck has their front long travel suspension and cantilever rear (which they no longer offer, pretty pricey btw). IMHO, not running a long travel or at least a mid travel front, you will still not get the proper look.
Baja kits prerunner kit. Tbere is a member here thay has the kit
Thanks everyone. I guess the main question here for the moment is: how do I get 35s to fit on a leveled truck?
Cut the fenders open with a muffler cutter, lose the bumper and spoiler, gut the fenderwells and put deep offset wheels on it.
Later, when you get about $5 grand, you can buy the front long travel suspension. Another $2 grand and you can get the fenders and bedsides.  A couple more grand and you can get the rear long travel suspension.  Maybe a grand for a front bumper, another $1-2 grand for some lights, paint, roll bar, and other miscellaneous.  Don't forget the $3k worth of wheels and tires.
There's a lot cheaper vehicles to go bangin around in the dirt than converting a 5000 lb fullsize crewcab truck into a dirt buggy.  As a bonus feature, you can still drive home in your bone stock truck when something breaks on the toy in the middle of the desert and drive the truck to work Monday morning, just a thought.  https://www.ebay.com/sch/Dune-Buggies-Sand-Rails/133220/bn_16581800/i.html
Edited by Spurshot
What about buying a 4 inch BDS with Fox coilovers and replace your stock bumper with a pre-runner bumper?  Some BW extend a fender flares color matched, and some wheel spacers, and you have something close to the look you're going for, and a truck that would still be practical.  You're looking at at least $5k if you follow my suggestion (probably closer to $7,500).
12 hours ago, Nasty said:
So you don't want prerunner you just want to fit 35s?
I do want a prerunner. I don't know what order to go in for mods that makes the most sense. It'd be all done over a 2 year process, but I can't seem to find anyone that can tell me what hard parts that 35's will rub on a leveled truck aside from the obvious(fenders and bumper).
Pull the bumper. Use a stock wheel. 35s will still rub but minimal
Sent from my SAMSUNG-SM-G920A using Tapatalk
Do you know what it will rub?
Fender well most likely
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
