I was thinking about the failed lifter issue.
The mileage when this happens varies a lot.
My thoughts are bad parts, extended oil changes, not disabling AFM or ?
I have always done 3 K mile oil changes on my vehicles.
My 2012 5.3L was purchased with 41 k miles, new oil and filter from dealer.
At 43 k miles the oil was really dirty.
Did a filter and oil change.
3 k mile changes since.
I have noticed the oil pressure gauge reading has changed. I posted about this.
It would idle at 40 psi when hot, now 30 psi.
Cold start psi was 50 as best as I could tell due to the design of the oil pressure gauge.
Now cold starts are definitely higher, 60 psi.
I have also noticed the motor is quieter at idle while standing by the truck.
Same oil and filter from the start.
I did get a Range device shortly after buying it.
Now living in the mountains I don't use the Range device due to the roads never allow it to get to 6th gear.
I drive it in manual now since learning the roads I drive.
I think a big part of the failures are bad parts but I wonder if some of the reasons I mentioned could play a part in the failures.
Thoughts?
I had a 30 year gm mechanic tell me that the AFM issue is due to using synthetic oil. I disagree with that unless people are using the oil life monitor or just thinking that you can go 15000 miles on an oil change. I run mobil 1 full synthetic with the dexos label on it and use either a fram or mobil 1 filter and change every 3k. I bought the truck with 103k it now has 127k and I only notice a little oil loss between changes. I have also disabled afm since around the 110k mark. This yearly oil that has been released now is insane to me.
as far as oil pressure my truck pushes 40 when cold at idle. once it warms up it usually hangs at 20 and then around 30 when moving. my truck has the 3.08 gears so the rpm is always lower than trucks with other ratios.
Edited by bgbdwlf2500
There is probably 100qty things to take into consideration of lifter failure?  You hear about more with Ford,GM, Fiat.......synthetic oil?  Probably not on the list that would be a first!  Anyway, Expansion/Contraction and how you go about your business is your problem..........So if your Johnny I fire it up and and 4-5-6K two blocks away you will have problems...many oil related issues too and other associated parts. I.e springs, cams etc........But attention to properly allow for expansion and contraction you will not have problems.......but you will all do what you do!
I too have been seeing lots of posts about the faulty lifters. Can someone give me the low down on the symptoms to look for that might show you have faulty lifters? Just want to get educated as to what I can do to keep an eye out for.
I have the obvious "DI clatter" but I also have this nifty feature that I burn about 1.5 to 2 quarts of oil every 3,000 miles. Truck has about 62,000 miles now, and I do oil changes only with Mobil 1 Full Synthetic DEXOS and Mobil 1 filters every 6,000 miles. I did buy it used at 27,000 miles so no clue what happened before me....
So what do ya think is worse? Saying it's so. Believing it's so or repeating it? :shakehead:
Here's the link to the post I made about this time last year when I had one fail
http://www.gm-trucks.com/forums/topic/196689-what-is-this-chirping/
Dirty, worn out oil is AFMs worst enemy.  Conventional oils are dead by 5,000 miles and anyone who has been around autos for very long has seen all the gunk those oils leave behind.  Synthetics in my experience leave nothing behind and will help clean out an engine full of conventional oil gunk.  This can cause problems for the AFM system.
AFM is a cool idea and its execution this time around is far better than during the 1980s on those 4-6-8 Cadillacs.  Same engineer involved in both projects.  Having said that, it needlessly complicates an engine (for the consumer, not GM having to deal with CAFE Standards) and offers little improvement to a heavily weighted truck like mine.  A good tune with AFM turned off results in better fuel economy anyway.
^^^This^^^
Before I had the issues with the lifters in my truck, I would average around 17 mpg, according to the DIC.
Since having the DOD/AFM kit installed and turning the AFM off with the Diablo tuner I got, I'm averaging about 18.5 mpg
No question these vehicles have zero tolerance for lack of maintenance, but domestics have been that way since the dawn of the automobile - nothing has changed there.
What HAS changed however, and is glaringly evident from where I stand (elbow-deep in grease, and under the hood of alot of different vehicles), is that long term reliability has gone down the toilet. The way these things are built today, is that they are designed to extract the most amount of money out of you as they can. No longer can someone just replace a certain part - now, it needs to be programmed to work. What a joke ... but I digress ...
Engines used to be off-limits to the "cheap-out express" ... but not anymore. These days they will cut corners anywhere and everywhere they can.
Just look at FoMoCo, with the 6.0 & 6.4 diesels - how many owners are out $20,000 after paying $60,000 for their trucks due to catastrophic engine failures? Look at the 4.0 DOHC engine with the timing chain cassette failures, requiring ENGINE REMOVAL and a pile of special tools to replace! Look at Fiat-Chrysler, with their notorious TIPM units that cause everything from your windows going down by themselves in the middle of the night, to a complete no-start, leaving you for dead on the side of the road. Then the HEMI's version of AFM that they must've copied from GM - those are failing around 90k - 100k miles. Lifter problems. Sound familiar? Some others are having valve guide problems. Then we have our beloved GM. Oil burner city, failed camshafts, failed lifters, failed valve springs, failed piston rings, FAIL FAIL FAIL!!!  :mad:
They create a great looking vehicle, with awesome suspension, braking, power, and handling, and wrap it all up in a shit sandwich, and we gulp it down willingly. There's soooo much wrong with that picture. Why do people put up with this? I know our grandparents, and great-grandparents would NOT have, especially with what they're getting for these things today!
Anyway, I could rant all day about the state of automotive affairs, but I've got more junk to repair. I'll leave you with some pictures of stuck GM AFM lifters out of a '08 5.3 engine:
If I may impose on your experience.
Compare the failure rate between the LS platform AFM (above) to that of the 2014 and later Ecotec3 AFM platform with point of reference. Example: X in a hundred motors sold experiences an AFM failure pre 2014 vs X units per hundred sold post 2014.
If you feel so inclined it would be useful to compare as well failures pre and post the AFM 'fix' era as well.
Thank you in advance for any information presented.
2014 is barely out of warranty - they'll start showing up in the next year or 2. Just like with my '07, the news didn't start rolling out until about 2010-2011. By then it was an avalanche.
I have already seen posts on failed direct injection injectors on '14 up - GM designed these in such a way that you have to replace the ENTIRE fuel rail on top of the engine whenever it is removed in any way. Real nice. Seen a post already on a '18 already having this issue. The '18's have some goofy box in front of the intake manifold that will leave you pulling your hair out, until you realize you have to remove the entire intake manifold to access the bolts! Another epic brainstorm ... but I digress.
Have yet to hear of an AFM repair coming back (unless it was completely botched by a rookie). I do know in the hotrod world, when you buy an engine from a place that does nothing else but build engines, they typically last forever, even with some heavy foot /  high RPM abuse. Same can be said of anything built outside of OE, depending on the company or shop. Bottom line is, if you do the best job you can, it'll be 100x better than OE.
Am going to hold onto the Avalanche till the wheels fall off.
If my recent lifter repair doesn't last, are there any long block replacements you would recommend.?Assuming Goodwrench wouldn't be one  of them.
Pretty much any company that builds nothing but engines. These days I wouldn't trust GM to tie my shoes.
Thank God they don't build aircraft ...
Edited by Jsdirt
So is the consensus that I will eventually have failed lifters on my 2012?
I would say "No," because there are too many variables; and, anecdotal evidence that some of these AFM engines have reached close to 300,000 miles without any other issue, than old age.
Since my cam lobes & pistons still looked good, I chose to only install the updated lifters, oil pan gasket, valve cover, oil pump pick-up tube o-ring, & VLOM.  Had already turned off the AFM, with my Diablo tuner.
Use Mobile 1, and change oil at around 5K.  If another failed lifter occurs, I will install a complete AFM delete kit, assuming the engine is still salvageable.  Never liked the idea of having a mix of longer & shorter lobes & lifters in my engine.
Also, will purchase the finest components that can be found.  Since I'm married to the Avalanche for the foreseeable future, it's good to have a plan.  All engines have some sort of hot-button issue.  For me, the AFM concern has become manageable.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
