I've read about some of the problems as well, but have not had any hiccups with my 2016 5.3/8 speed LTZ. I'm sitting at 43,xxx miles and the transmission has been flawless. That being said, I also have the piece of mind knowing the drivetrain in my truck has a lifetime warranty offered by my dealer.
Heck yeah. Man don’t get me wrong, I’m not bashing the transmission yet.. I love the 8 speed, I prefer it over the 6 speed
8 speed is much better if you’re modified
factory torque rating is way higher, and it does not cut power during the shift
Another easy way to tell, is the control unit is under the hood and mounted to the firewall just above the brake booster. I had to flush my trans. at approx. 26000 miles because I was getting the rumble thru drivetrain on freeway. I used mercedes fluid that is for fuel efficient trans. It had been about 3000 miles with no issues. Truck was also already tuned at 21000 miles by Pat G. Tuned makes truck night and day better.
1 hour ago, CarltonLee Martin said:
How to tell what transmission I have in my 2018 Silverado 4 door 5.3 ecotec
Move the shifter to manual mode and hit the up arrow until it stops.  You'll end up with either a 6 or an 8.
Welcome to the site.
That is an odd question, did you buy the truck new or used, and was it not listed either on the 4 square (Maroney sticker) or on the information provided by the dealership for a used truck?
If I am buying a late model truck, I like to know what I have just purchased.
On 4/15/2018 at 5:47 PM, 99Mastercraft said:
Thanks guys.. as of right now the only thing I am experiencing is when the vehicle is cold you put it in drive and it seems like when you first start there’s a slight hesitation and a clunk, but goes away after driving and does not exist when it’s warm... I could live with it, but I might see if there’s a software update for the trans before warranty expires
Dude you need to get that fixed asap. My 8L90e had the delayed reverse engagement when cold, there is a stator shaft that was a bad design, they have redesigned it since. My whole trans had to be swapped out, would have cost me $5,000cad out of pocket. Your trans will get worse and will fail, it will start to cause random intermittent torque converter vibrations eventually too. TSB 16-NA-014 https://static.nhtsa.gov/odi/tsbs/2016/SB-10097193-2280.pdf
It is all explained on page 1! It took you longer to become a member and register and then post your stupid question than it did to just simply read the 6th post in the thread...Good Grief!
Edited by NCPGMC
Good call sir!
I feel less intelligent after having participated in this thread.....
  • 4 years later...
A Monroney Label is a window sticker on a new car... a 4 square is a type/design of worksheet used to serve numbers
On 4/15/2018 at 5:05 AM, TJay74 said:
All 6.2 trucks from 2015 on got the A8, in 2016 all 6.2 trucks and any 5.3 truck with the LTZ/SLT package got the A8.
^^This^^
Btw, had a 2015 6.2L with 8sp, no problems in 75,000 + miles
had a 2017 6.2L with 8sp, no problems in 40,000 miles.
Trans worked perfectly.
R & R the ATF in both trucks before 10,000 with AMSOIL as I have done to every vehicle since 1979.  Not any trans problems yet. Been changed in my 2021 10 sp for 3.5 yrs / 40,000 miles
Edited by elcamino
Best way to tell which transmission you have is just put it in manual mode and go through the up and down buttons on the column shifter.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
