I recently spent $6,500 on this registered Black Angus bull. I put him out with the herd but he just ate grass and wouldn’t even look at a cow. I was beginning to think I had paid more for that bull than he was worth. Anyway...I had the Vet come and take a look at him. He said, the bull was very healthy, but possibly just a little young.
So he gave me some pills to feed him once per day. The bull started to service the cows within two days……. all my cows! He even broke through the fence and bred with all of my neighbor’s cows! He’s like a machine! I don't know what was in the pills the Vet gave him ... but they kind of taste like peppermint.  🤣
  • Haha 3
  • Replies 3.3k
Top Posters In This Topic
A man called a company and ordered their 5-day, 5 lbs weight loss program.
The next day, there was a knock on his door and standing before him was a gorgeous, 19 year old wearing nothing but a sign around her neck that said, "If you can catch me, you can have
me."
Without a second thought, he took off after her.
A few miles later huffing and puffing, he finally gave up.
The same girl showed up for the next four days and the same thing happened.
On the fifth day, he weighed himself and was delighted to find he had lost 5 lbs as promised.
He called the company and ordered their 5-day/10lbs program.
The next day there was a knock at his door and standing there before him was the most stunning, beautiful, sexy woman he had ever seen in his life.
She was wearing nothing but a sign around her neck that read, "If you catch me you can have me".
Well, he's out the door after her like a shot. This girl is in excellent shape and he does his best, but no such luck.
So for the next four days, the same routine happened with him gradually getting in better and better shape.
Much to his delight on the fifth day when he weighed himself, he discovered that he had lost another 10lbs as promised.
He decided to go for broke and called the company to order the 7-day/25 lbs program.
"Are you sure?" asked the representative on the phone. "This is our most rigorous program."
"Absolutely," he replied, "I haven't felt this good in years."
The next day there was a knock at his door and when he opened it he found a huge male gorilla standing there with a sign around its neck that read, "If I catch you, you are mine."
He lost 45 pounds that week.
Edited by MaverickZ71
  • Haha 1
16 minutes ago, MaverickZ71 said:
How bout them Packers?
I’m memorized by the Texans. There’re attitude (especially the quarterback) may bring me back to football. No NASCAR or Baseball I watch the playoffs. The keeling episode really made me angry. I’m not much of a fan of the Cowboys. Mainly because of the ownership. He killed a dynasty costing a few more potential Super Bowls.
Packers' offense is confusing for defenses. They have the tells of a cat. Every play looks the same in the beginning.
What did you do to get memorized by the team?   Did they ban you from the stadium or something?  Or is it up to a restraining order?
Got love that spell check. My wife of almost fifty years loves to correct my miss speak. I always say you know what I mean Lucy. Of course you have to be around my age to know who said  that.
Yes Ricky
  • Haha 1
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
