If you live somewhere they use salt on the roads in the winter, you've seen trucks 7-8 years old with rust holes in the bed, usually around the wheel wells.  Unfortunately, all too common a problem.  In an effort to slow the tin worm, I had my truck rustproofed by Ziebart.  Had good luck with their system in years past, so I figured I'd get my Silverado Ziebarted.  Now, this thread is not about how you feel about Ziebart or any of the other possible rust proofing choices, but what it's about is the bed wheel well liners.  I did not take the liners out when I had the truck rustproofed originally, but I was going to do that last year when it went in for it's yearly check up/touch up.  Forgot last year, but I removed them this year so they could spray the rustproofing product in the liner area, since it seems (to me at least) that when they begin to rust, that's the first area that starts to go.  Pics below are of the rustproofing installed.
Since I had the liners out, I figured I'd clean them with my power washer.  HOLY CRAP. :omg:  I wish I would have weighed the liners before I cleaned them, as there HAD to be 3-4 pounds of dirt in them.  I power wash that area a couple of times a year, but I'd never seen that much dirt and road gunk come out of them before.
That brings me to my current dilemma - do I reinstall the liners, or leave them out since I've got that area rustproofed now?  They obviously hold a lot of water close to the body when wet, along with a lot of dirt, possibly contributing to corrosion.  Then again, without them, even though the wheel wells have a coating of rustproofing material now, you have the possibility of rock chips that could be where corrosion begins.
Comments, ideas, discussion, thoughts  please.
The rust usually starts in the seam where the wheel well and bedside are tacked together. Dust/moisture/salt gets in there, and you can wash it out by sticking your arm up in the front of the fleetside of the the bed. However, they are bound to rust eventually. My 2006 is rusting in this area, and sees more gravel than most pickups. No chip rust, and I've never had liners, but it is rusting inside out.
Do they coat the inside of the bedsides?
Sent from my SM-G920V using Tapatalk
Yes, the underside of the bed is covered as well.  The bed will be getting a spray-in liner to replace the plastic liner before winter too.
I would absolutely put them back on, if not that rust coating and everything else will get washed away, or chipped away. Either way it will take a pounding.
Figure...you have it rust proofed, now cover it back up and hope for the best. That area gets a ton of air flow anyway...it should help keeep the moisture out of those covers a little bit.
I live in a rust belt, around where I am Fluid Film is pretty popular and NH Oil Undercoating. Whatever you use it has to be reapplied annually. I'll  have to check Ziebart out, never heard of them.
Funny i stumbled across this thread.  I was thinking about removing the factory carplet liners and replacing with plastic Husky wheel liners.  Takes a lot of time to wash the carpet lines.  Where as the plastic liner washes very easy....
I did reinstall the original liners, but I'd forgotten about the Husky liners. That may be a better way to go.
Where did you get your rustproofing done? I live in Geauga county and have yet to be referred to anyone that does decent work in my area.
Not real close if your in Geauga county, but I went to Ziebart in North Olmsted on Lorain Road.  Not far off of I-480.
Preventing stone chips is nice, but if the wheel liners trap dirt & salt next to the frame then they're probably doing more harm than good.
Best way to delay frame rust is an undercarriage wash & oil spray, every spring as soon as it's mild enough.
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
