2 hours ago, rkj__ said:
I'd be interested to hear more about that 4lo mimic button.  Any video reviews yet?
Watch from the 9:22 mark:
Thanks.  It's an interesting idea.  I really don't think I'd like it as a replacement for 4L.  If you use it for any length of muddy trail, it could lead to high brake wear.  Also, off road driving is risky enough, and I'm not a fan of having the vehicle control the brakes for me.  I never understood why "hill decent control" is a feature either.  Does anybody use that ever?
1 hour ago, Darmichar said:
Same here.  I use 4L every time I put the boat in or out of the water.
You use 4-low to pull an empty trailer up the ramp?
Where did I say that?
You said "putting a boat in" which would involve backing in, floating the boat off the trailer, and pulling out an empty trailer. Would it not? Why would you need 4-low for backing in? All youre using is your 4 wheel disc brakes backing in. Not sure where 4-low would offer any benefit over 2wd. I could see when retrieving and pulling the weight of the boat up a steep ramp.
Because, it's my truck and I'll drive it how I want.  I wasn't aware I needed permission to use 4L.
  • Haha 1
LOL
I used to offroad a lot. Also grew up in the hills and farm country of Michigan so rutted trails in the woods to get to your hunting land, a back field, or where wood was being cut was normal.
Not having 4 low just seems odd to me.  I can’t say I need it every day but having the extra 20lbs worth of gears in the transfer case doesn’t bother me.
Oh yeah, low works great in sand and mud. You just need to be in a higher gear.
I think it is a nice feature to have even if you don’t use it much or at all. I get why they are using two different transfer cases though.
  • 7 months later...
I don't understand why the 2 speed transfer case isn't available with the Max trailering package. Sometimes l need 4 lo to get heavy equipment to the job site.
This seems like a major over site on GM's part.
I can say this: I used 4L to get over a steep curb while there was a wall a couple feet past the curb and a car was parked inches away from my rear bumper. I was concerned I wouldn't use enough gas and hit the car behind me. Or overshoot the curb and hit the wall in front of me. In the meantime, I was on dirt so 4WD traction was necessary otherwise the rear tire would just spin. Fortunately, 4L was really slow and I was able to get over the curb then get out of the awkward parking spot.
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
