16 hours ago, Lion82 said:
Please do. Your input will be greatly appreciated.
Ok. So I can confirm it does interfere with the front parking sensors. All 4 of them. There is the parking assist switch which turns it off. The dealer screwed up and cut the plastic in the wrong place for the mounting brackets. That part is on backorder so I have until then to decide if I want a grill guard or front parking assist.
I back my truck in most places so front parking sensors aren’t really a big deal for me. The rear still work fine and instrument panel tells you which sensors are going off so all intents and purposes I think I’ll keep the grill guard. Having that protection on Montana interstates is more important than front parking assist.
Does not affect adaptive cruise, pre collision, or lane departure. That is controlled by the camera in the rear view mirror assembly.
Also I believe there is a relocation kit for those sensors, I will look into that and report back with my findings.
Thank you for the update. Please keep us posted on the relocation kit.
I found this, I emailed Westin to see if this corrects all 4 or just the center ones. As soon as I get a response I’ll holler.
Oh, and the mounting brackets mount opposite of the recovery hooks! So you don’t lose those, I though for sure they would use the same spot but Westin nailed it on that one(minus cutting the plastic) lol
Edited by Sierra50BMG
3 minutes ago, OnyxAT4 said:
Full detail:
Looks good! Did you add a leveling kit to your AT4? Also what size tires did you go with?
Yes, I went with the Rough Country 2” kit. As far as tire size goes, it came with the 18” wheels w/Goodyear DuraTracs but I traded them at my local shop for the factory 20”s w/ BFG KO2 285/65/20. No trimming, I haven’t done any off-roading to see if they touch anywhere at full use, but as far as city driving goes, no rub whatsoever at full turn.
I am trying to not spend as much money on this truck, as my last was modified more than any other vehicle I have owned. Lift, wheels and tires, re-gear, headers, full exhaust, tuned, etc.
Edited by OnyxAT4
Nice! That looks pretty much perfect. For my LTZ, I eventually want those same tires with the GM 2” Lift and a 1.5” level (or an equivalent 3rd party solution). This week, I just got a 1” level and non-LT 275/60r20 ridge grapplers to hold me over for a while.
Finally installed the Z71 grille badge that I have had for months and no you don't have to remove the grille to install!
They are separate lights the guy makes them with the wire harness and all
Would you be able to grab a quick measurement (Length x Height x Depth) of the LED housing? I am trying to see if I can retrofit this for the Sierra grille.
Thanks
Thanks
Yes l is 2 3/4 x h 1 1/4 x d 1” I would’ve made the height a little bigger
Awesome. Gonna see if the 1 3/4” high dimension will fit in between the grille slats. Thanks again!
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
