Just installed pedal commander works great
Was looking into this. Any warnings or error codes?
None yet I’ve had it for about a week already installed in my 2016 Silverado it did throw me into limp mode maybe twice but you turn of truck wait a couple of minutes then start truck back up and it’s back to normal
Awesome. Thanks for the info.
No problem it makes such a big difference that it’s worth the risk for the new body Silverado it model number pc77 just in case anybody is interested
On 3/22/2020 at 1:43 PM, loud_pipes said:
None at all. That was the Beauty. All plug and play, can be immediately turned back to stock.
Does your AT4 have lane keeping?  Is it affected by the light bar?  What p/n?
I don’t have lane keeping, but the write up says it is for vehicles that have it.
Amazon - Putco 92009-60 - here you go:
On 12/30/2019 at 8:17 AM, EXSlider400 said:
AT4 6.2 with Technology 2 and Performance packages.
-Tint
-Tires (factory size General A/Tx)
-Removed “SIERRA” from tailgate
-Relocated Antenna
-Hitch and license plate covers
-LED license plate bulbs
-Ceramic coated/waxed
-1/2” front level (may add another 1/2” and UCAs later)
Future: Powder coat exhaust tips in Black Chrome and run resistor so fogs come on with high beams (researching now what wire location numbers are needed).
Great looking truck!  What colour is this? Carbon Black Metallic?
Thanks.  Smokey Quartz Metallic
The one different color between Silverado/Sierra is Oakwood Metallic on the Silverado and Smokey Quartz Metallic on the Sierra. Not only do the two colors have different names, but they also have different color codes and touch-up paint numbers.
Edited by EXSlider400
Got my truck ceramic coated with Gyeon Duraflex. Pictures are after first layer applied. Will have more pictures when second coat cured.
Pictured mods also include pain matched  mirror caps/door handles, fogs, and side steps also installed recently
Did you paint the factory mirror Caps and door handles or did you buy separate ‘paintable’ ones and have your body shop shoot them?
Edited by Kableguy
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
